Front Fender modification/fabrication
Old Jun 19, 2012 | 12:07 AM
shrini23's Avatar
shrini23
Default Front Fender modification/fabrication
I'm tired of my small front fender look on my dyna
Attaching a pic of the front fender from heartland website (For illustrative purpose only)
Has anyone fabricated a front fender like this?
I'm planning to fabricated myself, would love to know the dimensions & curvature if someone has done before me.
Last option would be to buy., If someone has purchased it in the past pls share me the link & it'll be of great help
Attached Thumbnails Front Fender modification/fabrication-front-fender.jpg
Old Jun 19, 2012 | 05:37 AM
rs87277's Avatar
rs87277
I like the look of that fender
Old Jun 19, 2012 | 06:28 AM
J.Sizer's Avatar
J.Sizer
I want it
Old Jun 19, 2012 | 06:40 AM
8541hog's Avatar
8541hog
You will have some fabrication to do even if you buy that fender. You will want to cut down the mounting tabs and get it set right on the wheel. Nothing difficult, but I would buy it before I tried to fab a whole fender, and I enjoy fabricating parts.
Get some of that sticky-back foam insultaion strips from home depot, put it on the tire in the thickness you want between the tire and fender and mark the mounting holes.
Then bolt it on temporarily and mark the tabs to match the mount and grind it down so they look like they were made for each other.
Old Jun 19, 2012 | 08:48 AM
WanaRyd Wheels's Avatar
WanaRyd Wheels
Sponsor
Klock Werks offers fender options for dynas, check out their site. Let me know if you're interested in getting a discounted quote on any of their products plus proper lead time.
Hope you find what you're looking for. Ryd Safe!
__________________
WanaRyd Motorcycle
1-888-926-2793
Old Jun 19, 2012 | 08:58 AM
trip20's Avatar
trip20
you can buy a blank and cut out the shape you want
Old Jun 19, 2012 | 09:56 AM
Hogpro's Avatar
Hogpro
Former Sponsor
We mocked up a similar fender a few months ago on a wide glide which has a 21" as opposed to your 19" wheel. It looked great. I'll find out more about what fender it was and see if there is a 19" option for your bike. I prefer the way a wrapped front fender hugs the front wheel. It gives the bike a very sleek look.
Of course I can't find a pic of it.
Old Jun 19, 2012 | 10:08 AM
JRK5892's Avatar
JRK5892
i got a 120/21 fender blank. used a 21 ring to get my line and cut it out for the blank... i will prep you and say i went with the metal fender so that i could powder it... and cutting it was a bear... after it was cut i used the belt sander to smooth the curves and make it uniform, then the angle grinder to smooth out the tight spots... have about 9 hours into it but it was worth every second for the final product
after cut out and shaping
coating
had to clear the fork brace
kept it nice and tight
in my opinion this mod only looks right if your rear fender matches... i have seen several wrap around fronts and stock rear fenders and it just does not flow well with the bike... but if you stretch your rear fender a bit (i did 4 inches) it looks baller
Old Jun 19, 2012 | 11:33 PM
shrini23's Avatar
shrini23
Thanks Joe.
@JRK5892 you gotta PM
EricInNCa
Dec 17, 2009 12:07 PM
low_n_slow
May 30, 2009 08:17 PM
1cerberus4u
May 20, 2009 07:20 PM
XARAN
May 6, 2009 11:18 AM
Crazy Canuck
Dec 13, 2005 08:02 PM
