I was wondering if someone with these pipes can help me.
I have them on my bike and thought I'd discovered a hole next to the bracket that holds the pipe on near the passenger pegs.
Once the bike had cooled down and I was able to slip my hand in between the pipe and the bracket the hole feels kinda regular and uniform so now I'm thinking a screw might've vibrated out or something. Because its between the pipe and the bracket I just cant see the damn thing!
the only holes in the pipes are where the 02 sensors go, one up front and one just above where your speaking of.
if you have a piggyback device that eleminates the 02 sensors somone likely had them pluged with a bowel plug.
i lift my sensors hooked to the pipes so if the pcv craps out on me i can go back to the stock set up to get her home.
I dont think that's exactly right as I know there is already one screw holding in the baffle which you can access from the outside of the pipe. If you look you'll see it just poking out, little button head allen screw.
sorry man i forgot about those. i can look after work for u.
Thanks man that would be amazing, because if it's just one of the baffle screws it would be a big relief!!!! I could also get my SmartzPartz baffle in too without taking the exhaust off!
