PM grip install and cable adjustments
Old Jun 21, 2012 | 12:25 PM
tnkrizzo's Avatar
tnkrizzo
Default PM grip install and cable adjustments
I just got in my Performance Machine grips in today and installed them. On the throttle side, I have a question about the cables. I slowly removed the old grips without moving the cable adjusters and they even went on just fine. My concern was when it was all completed, the drip was rather loose. I tightened up both cables, but how much play should each side have? Right now, I hardly have any play when opening up the throttle, and there is very little when it is fully released. Should I go back to the "factory" settings that were very loose, or am I just fine where I am at? It has been 20 years since I last installed grips, so I am like a novice here again!
Thanks for your help.
Old Jun 21, 2012 | 12:40 PM
8541hog's Avatar
8541hog
Adjust the throttle cables to the feel you prefer, I like mine with very little slop in them, as long as you do not over tighten or take out all play you will be fine.
Rogue8Man
Aug 14, 2016 06:17 PM
schecter5150
Sep 17, 2013 07:23 AM
Nostalgia_93
EVO
Aug 28, 2013 06:23 PM
scot210
May 4, 2011 07:29 AM
hdjoe88
Jan 5, 2007 01:43 PM
