Installing apes, need some help...
Old Jun 22, 2012 | 08:06 PM
trainedkilla's Avatar
trainedkilla
Default Installing apes, need some help...
Gentlemen,
I have partially installed some 14" apes and I have some questions. I still have the clutch cable to do and it appears that I have to remove the exhaust and take off the clutch cover to do this? Am I correct? Anything I need to know before pulling it off?
Second, I put the right controls on and am having trouble adjusting the throttle. Was I suppose to grease the bars before putting the throttle back on? If so, what type of grease?
Thank you!
Old Jun 22, 2012 | 08:19 PM
2009Bobber's Avatar
2009Bobber
1. Yes, you have to remove the exhaust. Although I have a street bob and not a wide glide, I don't think there's a difference.
2. I greased both sides of the bars before putting the grips back on. I used white lithium grease spray. I didn't have any throttle issues.
GL and enjoy the bars. They'll look great on a wide glide
Old Jun 22, 2012 | 08:22 PM
hellbob37's Avatar
hellbob37
Originally Posted by trainedkilla
Gentlemen,
Thank you!
Don't grease the bars the throttle assembly should slide right on. It's held in with the control housing. Yes you need to remove the clutch cover. You'll need a set of retaining ring pliers, big ones. And just take note of where and how the internals go back together. As well as the bolts that hold the cover on, they're different lengths. Now is the time to do an ez pull if you want, everything will be out. You'll also want to loosen the cable all the way, will make getting it onto the hub much easier. Good luck.
Old Jun 22, 2012 | 09:31 PM
trainedkilla
Thanks alot for the advice. So, if the throttle is not snapping back properly, I must have something installed incorrectly? I can not get it to adjust.
Old Jun 22, 2012 | 09:45 PM
PMB3's Avatar
PMB3
Make sure your throttle adjusting screw is not screwed in.
Old Jun 23, 2012 | 05:57 AM
hellbob37's Avatar
hellbob37
That and when you put the throttle on, to get the cables into the actual throttle I loosen them up pretty good. Take note of which stock cable has the spring on the end that goes into the TB/carb, in which hole I should say. Also I take the intake off so I can see where wide open is, the butterfly will go flat. Once that's correct, adjust the return spring so there is a little play in the housing and you're good. Just make sure you get that little spring into the right hole.
Old Jun 23, 2012 | 10:04 AM
PMB3's Avatar
PMB3
I think you mean you take of the air filter backing plate not the intake?
Old Jun 23, 2012 | 10:15 AM
trainedkilla
Ok...I have everything installed and adjusted. I had to put lithium grease on the bar. It worked like a champ after that.
My problem now...I have an engine light. What would cause the bike to throw a code?
I did not unplug the battery during install...could that be it?
EDIT:
Nevermind! I did not ensure one of the plugs were completely closed. It is all done!
Old Jun 23, 2012 | 10:30 AM
128auto's Avatar
128auto
If the throttle is binding, check the right control clamps and switch housing, it may not line up and putting pressure on the throttle grip, I've seen it many times. Don't forget to check the throttle thumb screw, it could be tight as well.
Vito Orso Basile
Feb 24, 2017 01:10 PM
vahalla
Feb 22, 2017 06:10 PM
Pbjohns
Apr 9, 2014 02:48 PM
wrightd
Sep 20, 2010 09:19 AM
wrightd
Aug 29, 2010 11:28 PM
