Clutch adjustment
Old Jun 25, 2012 | 06:22 AM
TGWN's Avatar
TGWN
Default Clutch adjustment
I adjusted the clutch per the manual that I have. It calls for 1/2-3/4 clearance and then tighten the nut. I set it at the 1/2 inch clearance. Does it matter if you set it at 1/2 or 3/4? I'm thinking truck because you set them at the smaller and they wear to the larger. It works fine, just wondering.
Old Jun 25, 2012 | 06:28 AM
RLE's Avatar
RLE
Just did mine yesterday. My manual states 1/2 to 1 round, I went 3/4. Works great.
Old Jun 25, 2012 | 06:39 AM
TGWN's Avatar
TGWN
I have got to get some reading glasses in the shop. 1/2-1 inch is right.
Old Jun 25, 2012 | 06:59 AM
FXDWG12's Avatar
FXDWG12
I think that there is going to be a pretty big differance between 1/2 turn and 1/2".
Old Jun 25, 2012 | 07:06 AM
TGWN's Avatar
TGWN
Be nice I was typing and waiting for the coffee to brew.
Old Jun 25, 2012 | 07:10 AM
maddghost's Avatar
maddghost
No buddy it is 1/2 to 3/4 turn not inch!you loosen the cable completely hold the allen screw while you loosen the lock nut. holding the nut you turn the allen screw in until it just barley makes contact, then turn the screw back 1/4 to 3/4 turn, hold the allen screw (don't let it move) and re-tighten the locknut, then adjust your cable.
Edit = I'm guessing you knew that and just made a type-o. Good morning to you ! I can't help wondering how RLE's clutch is though!!
Old Jun 25, 2012 | 07:14 AM
FXDWG12's Avatar
FXDWG12
Ohhh! So thats what they'r calling "alsimers" these days.
Old Jun 25, 2012 | 07:18 AM
maddghost's Avatar
maddghost
What did you forget how to spell alzheimer's? LOL What does that do again????? LMAO
seriously my dad has that and it is no picnic.
Old Jun 25, 2012 | 07:40 AM
TGWN's Avatar
TGWN
OK coffee in and breakfast down. 2010 FXDC. Do all the manual says to the point of 1/2 to 1 turn out and tighten the nut. Now that the readers are found I am setting it at 3/4. If I can remember.
Old Jun 25, 2012 | 09:17 PM
RLE's Avatar
RLE
my clutch works great, why do you wonder? I went 3/4 round. Manual states 1/2 to 1. I went right in the middle.
