'12 Wide Glide
Old Jul 5, 2012 | 01:35 PM
usaf_branham's Avatar
usaf_branham
Default '12 Wide Glide
After years of gawking, I finally pulled the trigger and picked up a Vivid Black 2012 Wide Glide about 3 weeks ago. I already pulled the reflectors off of it and plan to install the chopped rear fender brake/running light on it. My only real complaint is how quiet it is.
I love the look and sound of the v&h big radius 2 into 2's, however, I am not trying to dump a bunch of money in to this (like I did my Mustang). I guess I have a few questions before I decide on which route to go.
Is it absolutely mandatory to get the bike tuned if I put the v&h pipes on?
How much does slip-on mufflers affect a/f ratio?
While I am waiting to either get a set of slip-on's or the v&h exhaust, I am thinking about disassembling my stock mufflers and modifying them to get some more volume out of them. I understand that I can punch out the baffles with a piece of rebar or drill out the rivets and actually modify the guts. If I were to do this, would it cause any problems with the bike?
I do like the stock look of the bike, and $350 for a set of slip-ons seems to be a tad bit more responsible than $700 for v&h + a/c + tune.
Also, the bike has a catalytic converter built into the stock exhaust... I fired the bike with the top muffler removed and it was not dramatically louder than it was with the muffler installed. Granted, it was louder (and sounded more like a harley), but I am wondering how much that Cat is muffling the exhaust.
Old Jul 5, 2012 | 01:51 PM
Redbeard's Avatar
Redbeard
I have Rush slip-ons on mine to maintain the stock look, but they definitely improved the sound (even with the cat in place).
And you don't really need a tune until you free up the intake side.
Old Jul 5, 2012 | 01:53 PM
Kevinmach1's Avatar
Kevinmach1
I have a set of Rush slip-ons for sale that are in PERFECT condition. Not even 1000 miles on them. They sound great.
Let me know, I can make you a deal.
Old Jul 5, 2012 | 02:15 PM
FlatBlack12Bobber's Avatar
FlatBlack12Bobber
To put the V&H 2 into 2's, you need a tuner and a high flow intake....it's about 2 grand for everything involved installed
Old Jul 5, 2012 | 02:37 PM
Good_Apollo's Avatar
Good_Apollo
You can install just the pipes. If he is just after sound and not performance (which I'm sure he is since those pipes kill performance) you can just put pipes on and not tune.
The rule of thumb that many follow is just pipes is fine, just air cleaner is fine, but both is when you should tune.
Old Jul 5, 2012 | 03:00 PM
WG2011's Avatar
WG2011
I got good dyno numbers with my 2 into 2.
Sound like slip ons are what your after to the op.
Old Jul 5, 2012 | 03:03 PM
FXDWG12's Avatar
FXDWG12
Nice to meet you brother!
Thanks. This gives me back some of the confidence in what I've been taught over the past 5 years of cycleing.
Old Jul 5, 2012 | 03:13 PM
DeerTexas's Avatar
DeerTexas
Greetings! I've got 2 in 2 VH Big Radius pipes and a screaming eagle breather on my '12 WG. Sounds and runs great, but decel pops are a mfer. Was told I need a racing tuner to remove the pops. Good luck.
Old Jul 5, 2012 | 04:59 PM
Bagger Jim's Avatar
Bagger Jim
You should start saving for a tuner of your choice, cause you're going to need it sooner or later. As for pipes, I'm kind of partial to the V&H big shots. They have a built in crossover to blend the exhaust from both cylinders, so they are similar to a 2 into 1 with the look of a 2 into 2. Seem to make decent power also. Congrats on the new scoot!
Old Jul 5, 2012 | 05:22 PM
J.Sizer's Avatar
J.Sizer
welcome to the wide glide club.
mausc
Apr 20, 2017 07:41 PM
CoolWideGlideGuy
Sep 14, 2013 12:52 PM
billbuzz
Sep 26, 2012 08:18 PM
usaf_branham
Jul 25, 2012 09:08 PM
valvestem
Sep 2, 2011 07:08 PM
