Cough through carb.
Old Jul 9, 2012 | 07:17 PM
florida gus's Avatar
florida gus
5th Gear
Default Cough through carb.
Hey guys
I need a little info. trying to adjust the carb on my 2002 low rider. I have screwed the mixture screw all the way in to seat,backed of two and a half turns seem to be a little better but not quite right.It coughs a little if i cruse at about 3000 rpm or less,but if i run up to about 3400 rpm or over it dont miss a beat.i was thinking the person who had it before me let it get a gunked up.Before i have it rebuilt is there a good additive to try and run through it?
What is the maximum turn's i should back off on the mixture screw,like i said i am at about 2 and a half now.
Thanks for any any info.
Old Jul 9, 2012 | 08:13 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
Sent you a PM on a real inexpensive carb trick.Have you tried running a couple of tanks of fuel with some Seafoam or other reputable cleaner in the gas?
Old Jul 10, 2012 | 05:25 PM
florida gus
5th Gear
Someone told me to try the sea foam.I will give it a try first and then this weekend if it dont help i will try the other.
Thanks for your reply
Old Jul 10, 2012 | 05:43 PM
DanDman's Avatar
DanDman
I'm having the same problem on my '03. Misses/hesitates/coughs at 3000-3200 rpm. I ran three tanks with Sea Foam, and two tanks with Chevron Techron Concetrate added. Didn't make a difference. Plugs looked good. I didn't want to mess with the jetting, but looks like I have to. Did some research and it may be the needle jet. I bought the bike used and the seller was no help on the modifications done. Pipes and a Sreamin Eagle air cleaner have been added. What was the other tip you are going to try?
Old Jul 10, 2012 | 07:41 PM
TyeAdair's Avatar
TyeAdair
You're running a little lean. I had the same problem and it turns out tr previous owner didn't do any adjustments to the carb when he added pipes. I went from a 45 to a 46 jet and it runs like a champ now.
Old Jul 10, 2012 | 07:42 PM
seniorsuperglideE8
A lot of guys and some gals buy a previously owned bike where a stage one was done. Air cleaner and pipes. Then they take some where to get it tuned. The shop sells a Dyna-jet kit (quick $100) and install/tune. I've read a lot of threads where the dyna-jet wasn't all that good. Different jets, different needle, a softer diaphram spring and a larger hole in the vacuum piston slide. Some may have a good kit nstalled but more haven't.
oly22
Carburetor Related
Jan 22, 2019 04:06 PM
cavalier2000
Jan 10, 2011 04:57 PM
kenward
Apr 20, 2009 05:09 PM
Batsy74
Shovelhead
Sep 9, 2007 09:25 PM
1958pan
Exhaust System Topics
Aug 15, 2006 01:58 PM
