2012 dyna short shots installation problem
Old Jul 11, 2012 | 01:47 PM
Foxster's Avatar
Foxster
Originally Posted by ash uk streetbob
have you done the same foxter? if so did you get an error?
Yeah though I removed the hole thing way I see it good weight reduction lol
I did do it but fitted an eliminator plug at the same time so I dunno if it would have throw a code if I hadn't.
I worry about those kind of things because some ECUs will drop into a limp-home mode if it detects faulty sensors to prevent damage to the engine.
You can get the eliminator here, along with the one for intake when you finish the stage-1 and swap out the air cleaner: http://www.vtwinmania.co.uk/product_...sid=mvhzyhphbk
Old Jul 12, 2012 | 06:49 PM
cobb04's Avatar
cobb04
I just put on some khrome werks 3"-Hp slipon so I haven't removed the solenoid. I did the stage one in stages. Pipes plus xied leads 1st. I left the exhaust solenoid plugged in. Initially all was well but then bike developed a bad flat spot. I unplugged the solenoid and cured. No fault light. However harley said it would be recorded on ecu and may go to limp mode. It never did. When I put on an alren ness big sucker kit I bought the eliminator plugs too. Apparently it will definitely fault with airbox solenoid unplugged. My bike now goes fantastically and sounds awesome. good luck with it.
blair
Sep 1, 2013 09:21 PM
FatBri
Jul 13, 2011 10:48 AM
FireRyder09
Dec 2, 2009 10:49 AM
harlista01
Oct 25, 2009 05:02 PM
rob_will
Jan 18, 2007 01:50 PM
