BLACK matching shifter & brake levers
Old Jul 19, 2012 | 09:15 AM
Kbi83's Avatar
Kbi83
Angry BLACK matching shifter & brake levers
I need some help, I've never had this hard of a time trying to find bike parts.... all i want is 2 black matching shifter and rear brake levers and on the brake side i want to be able to screw in the brake peg, so everything matches.. ive only found one and it was 400$ and theirs no way im paying that for a lever
2012 wide glide..
thanks for any help you can give me..
oh and ive seen the ones at the stealership, but that one has a built in brake peg its not interchangeable.
Old Jul 19, 2012 | 09:31 AM
JRK5892's Avatar
JRK5892
send them to me... ill powder them
Old Jul 19, 2012 | 09:38 AM
Kbi83's Avatar
Kbi83
powder coating isnt really an option, since i want the interchangeable brake peg.. if it comes down to buying chrome and powder coating i can have that done locally at no cost.. but thx for the option
Old Jul 19, 2012 | 09:46 AM
JRK5892's Avatar
JRK5892
then i must not understand your question at all
Old Jul 19, 2012 | 10:02 AM
Kbi83's Avatar
Kbi83
Aright here's what im wanting to do.. the shifter side you can add a different peg to the top of the shifter to match your foot pegs i want to do that on the brake side instead of having the square rubber piece
Old Jul 19, 2012 | 10:15 AM
JRK5892's Avatar
JRK5892
just machine that off and tap it... done and done.
Old Jul 19, 2012 | 10:38 AM
EricInNCa's Avatar
EricInNCa
They make different brake pedals (that bolt on the factor brake arm) that match the shift levers. What shift lever do you have? Did you look at the HD website?
Old Jul 19, 2012 | 10:43 AM
ryderbiker's Avatar
ryderbiker
You can modify the stock brake. I cut off tr pad and rounded out the arm. Then I drilled a hole and mounted a peg. Not too difficult.
Old Jul 19, 2012 | 10:45 AM
Kbi83's Avatar
Kbi83
alright.. that looks to be the only option..
thanks guys
Old Jul 20, 2012 | 01:21 AM
pokey074's Avatar
pokey074
The factory brake lever has a hole in it for mounting HD and aftermarket brake pedal pads, of which Harley makes plenty. I'm going with the "tribal" bad and shift lever.
http://www.harley-davidson.com/gma/g...bmLocale=en_US
FFZHD
Stock Harley Take Offs
May 16, 2015 11:29 AM
fgallardo
Mar 29, 2010 04:22 PM
Sodiee
Aug 22, 2008 06:58 PM
swicegk
Apr 23, 2008 12:52 PM
ratzila
Aug 1, 2006 11:20 AM
