Lowrider Indicator Lights
Old Mar 6, 2007 | 11:45 AM
Sammi's Avatar
Sammi
Default RE: Lowrider Indicator Lights
Thanks.
And you used the existing light display?
Sammi
Old Mar 6, 2007 | 11:56 AM
john8123's Avatar
john8123
6th Gear
Yes, the whole display. The wires originate from the console, so it made it easy to hook everything back up.(no cutting of wires)
Old Mar 6, 2007 | 06:18 PM
Timmer's Avatar
Timmer
ORIGINAL: john8123
Roadrider18
Thanks
Here is two pics with them lighted, sorry one is blurry. Cold here and my camera does not like it.
You were right it was a tight fit. Up and down fit great with lots of room. From side to side it was tight, I had to bend the mounting bracket a little and then it all fit right into place.
[IMG]local://upfiles/16110/8F41991DC8E54FF2ADBC6C24BBA695B0.jpg[/IMG]
[IMG]local://upfiles/16110/47BC3F7E3AE146F3947304292B8F9125.jpg[/IMG]
RR, man that looks really good. The mounting bracket worked okay for you? What did you use to cut out the console, a dremmel? Something that wouldn't booger it up too much,huh?. Timmer
Old Mar 6, 2007 | 07:15 PM
john8123's Avatar
john8123
6th Gear
I first taped up the whole console, so not to get it scratched. My dremell battery was dead, so I used my cordless jigsaw with a metal blade and worked VERY slow. The existing bracket worked fine, but I had to bend it in a couple of places so the display woulkd fit in between.
Old Mar 6, 2007 | 07:47 PM
kzad's Avatar
kzad
That looks great John. I thought about doing that, but I thought it might be too tight a fit. Guess I was wrong!
Old Mar 7, 2007 | 03:51 PM
Timmer's Avatar
Timmer
Kzad, has your lights ever come loose from them just being superglued and siliconed? Timmer
Old Mar 7, 2007 | 06:35 PM
kzad's Avatar
kzad
Might be a few more weeks before I can answer that question (Connecticut) ...I don't think it will be a problem because I had a nice tight fit...actually had to push them into the holes.
Old Mar 16, 2007 | 11:54 AM
2dales's Avatar
2dales
Great work JOHN8123, this will definately be the way I go when I change out my stock headlight.
Old Jul 11, 2007 | 04:00 PM
Timmer's Avatar
Timmer
Kzad, how are the lights holding up? Tim
Old Jul 11, 2007 | 05:39 PM
Stanger's Avatar
Stanger
Awesome job to all of you. I just got a low rider console and I have been wondering how to do all this and now I know!!
Thanks
