12 year old 4300 miles backfiring
Old Jul 19, 2012 | 12:28 PM
Jimall's Avatar
Jimall
Stage I
Default 12 year old 4300 miles backfiring
I just bought a 2000 Low Rider with 4300 miles. It cruzes at about 2000RPM but when i turn the thottle it popps & backfires out the pipes the more i turn it the more it backfires & ruffer it runs. I letoff the thottle back down to 2000RPM & it smooths out. All i have done to it is change all the fluids. when i was checking the air filter it seemed loose so took all the bolts out & the carb came off in my hand, so i put the seal & carb back on it feels ok now. But can't figure out the problem, can anyone help?
Old Jul 19, 2012 | 01:21 PM
Good_Apollo's Avatar
Good_Apollo
Change your plugs as a first step
Other than that, might be something going on with the carb or the intake or exhaust gaskets. Could be a lot of things causing popping and backfiring.
Old Jul 19, 2012 | 03:16 PM
Robtarra39's Avatar
Robtarra39
maybe a new carb to intake seal, sounds like a vacuum leak
Old Jul 19, 2012 | 03:25 PM
Hogpro's Avatar
Hogpro
Former Sponsor
Have you cleaned the carb out? That would be my next step after doing plugs. A bike that old with only 4300 miels surely has some shellacked gas in it.
Old Jul 19, 2012 | 03:29 PM
Spud17's Avatar
Spud17
If I read that right and you said the carb fell off in your hand, I would replace the gasket between the carb and intake.
Old Jul 19, 2012 | 03:34 PM
tazzzman's Avatar
tazzzman
I agree, sounds like a vaccum leak. Also, check your fuel line for cracks. If the bike sat for a while, dump the gas and put in fresh. If all that doesn't cure the prob., do a thorough carb clean. Good luck!!!
Old Jul 19, 2012 | 03:35 PM
tazzzman's Avatar
tazzzman
Also check for fouled plug
Old Jul 19, 2012 | 07:32 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
Also lift the top of the carb and check the rubber on the vacuum piston assy. for holes. the accel. pump could be adding gas but the slide won't lift to allow more air. A good cleaning of the carb could be in order.
TheShadow619
May 5, 2016 11:45 AM
straightleg
Exhaust System Topics
Jul 10, 2013 07:14 AM
ryamatt
Jul 28, 2012 03:16 PM
brwdarr
EVO
Dec 14, 2010 07:15 PM
ped733
Dec 5, 2007 03:15 PM
