ok, so I'm supposed to squeeze the jaws together all the way? then put the remover body over it with the washer and the nut, snug it down and tap the rod in to expand the jaws, then crank the nut, pulling the bearing?
Yes. Squeeze them together a little so you can get them jaws into the bearing. I had to tap a little with a mallet. Put the body on, get it mostly tight but with a little play, then tap the rod in. Turn the nut and the bearing comes out.
Reason: Autocorrect homophobia
ok, got it... the bearings are out. that's exactly what is done.
I had to squeeze the jaws together so they'd go into the bearing. once that is done i slide the puller body over it with the washer and nut next. snug it down then tap the rod in.
once the rod is it, just crank the nut. the bearings come right out.
it just looked so funny at first.
i definitely like the other design better where you tighten it by turning it THEN put the body on... like the video...
I think the heart land tool is way over rated. I went to harbor freight and bought a blind blind hole bearing puller set, now i have a tool i can use on many other things. I made a little tool to hold the bearings and just tapped the new bearings back in. You can use an old cam too.
I don't think the Heartland tool is overrated. I think it's overpriced, but it's a specialty tool and would cost a lot less if they sold a ton of them. The puller isn't anything special, but I wouldn't want to try to install new ones without the installer. Not saying other people can't but personally I don't have any confidence in myself to pound new ones in straight or seat them to the correct depth. And the heartland version is WAY cheaper than the JIMS tool.
It's interesting to note that a practically new engine already has .007" crank runout though. A few years ago, that would have been well out of spec.
I'll never understand why the MOCO doesn't just get the cranks to near-zero runout, then weld the crank pins. Seems like that would prevent a lot of warranty replacements later.
Oh well, who knows what they're thinking.
