Question on pipe wrapping
Old Jan 16, 2007 | 05:35 PM
darkvisorman's Avatar
darkvisorman
Default Question on pipe wrapping
I have read a few posts on here regarding pipe wrapping, the question i have is once they are wrapped to they have to be sprayed with anything? i seem to remember a post where they were sprayed, is so what was used? Or am i going mad? - DVM
Old Jan 16, 2007 | 05:46 PM
glideridemike's Avatar
glideridemike
Default RE: Question on pipe wrapping
there is a product they recommend to spray it with that helps harden the material up a bit. It also is a silver color so it helps improve the looks a bit. You should be able to get it wherever you get the wrap from.
Old Jan 16, 2007 | 06:11 PM
darkvisorman
looking to use graphic black wrap can you spray with bbq black paint?
Old Jan 16, 2007 | 06:16 PM
CHEESE's Avatar
CHEESE
I didn't use any coating on mine, not saying that I won't, but I haven't yet. I don't want to change the color of the wrap at all, so I'm trying to find something totally clear. A lot of the guys that use black wrap use the black spray, because some of the black wraps are more of a grey, and the spray is necessary to make the wrap black.
Old Jan 16, 2007 | 06:18 PM
glideridemike
Check with the place you are buying the wrap from.
Old Jan 16, 2007 | 06:27 PM
darkvisorman
thanks guys, so are we saying that any hi temp black spray would do the job, i used to spray the headers of my hayabusa with just black bbq paint, is this ok to put over the wrap material? or an equivalent hi temp spray? my wrap that i am doing at the weekend is graphite grey and i really wanted dark black.
Also it is better to single or double wrap headers and pipes?
Old Jan 16, 2007 | 07:21 PM
Alaska Bobber's Avatar
Alaska Bobber
If you sit in traffic alot...double wrap those puppies. Your inner thigh will thank you.
Old Jan 16, 2007 | 09:19 PM
pococj's Avatar
pococj
Don't use the high heat black. Get the stuff made for the cloth. It contains something that'll help preserve it.
Old Jan 17, 2007 | 12:04 AM
steelcowboy's Avatar
steelcowboy
If you do go with the hi temp paint don't get the BBQ. BBQ paint is only rated for about 600 degrees and since manifold temperatures "can" reach over 1000 (in the bends) it tends to burn off the paint. What you need is header paint your not going to find it at Walmart but its not that hard to find alot of parts stores are going to have it if you ask. It comes in a few different colors including my favorite BLACK. You'll have to pay a little extra per can but you'll save in the long run I promise. Oh and someone was saying earlier about the double wrap. I had enough trouble wrapping them with one layer I can't imagine trying a second lol. But you are right its still hot enough in spots to burn my pant legs.
Old Jan 17, 2007 | 12:12 AM
Tolly's Avatar
Tolly
I wrapped mine black and it did look gray until I sprayed them with a high temp silicone coating.
http://www.eastwoodco.com/shopping/s...keyword=DEI004
