does anyone know how to remove the springs
Old Jan 16, 2007 | 10:59 PM
speed8988's Avatar
speed8988
Default does anyone know how to remove the springs
Do you need a special tool to remove the springs from the shock unit? I have them off and I'm tryin to figure out how to remove the top and bottom and springs so I can powder coat.
Old Jan 16, 2007 | 11:55 PM
mud's Avatar
mud
Default RE: does anyone know how to remove the springs
ORIGINAL: speed8988
Just exactly which machine are we workin on speed??
mud
Old Jan 17, 2007 | 08:30 AM
piniongear's Avatar
piniongear
Yes you will need a spring compressor tool to get the springs off and later, to put them back on. These tools can be shop made if you are so inclined, but like Mud said, 'What kind of machine are you working on?'..........pg
Old Jan 17, 2007 | 09:06 AM
Roadrider18's Avatar
Roadrider18
DO NOT attempt to remove the caps of any coil-over spring without a spring compression tool. Very dangerous to proceed without!
Old Jan 17, 2007 | 09:14 AM
Boxjoint's Avatar
Boxjoint
You can make a spring compression tool if ya have any flat steel laying around. Just notch it for the piston shaft and put one hole on the other side. Use 2 long bolts and compress:
________
IO I
I ___ I
I I II
I I I I
I I I I
II I I
I---I I---I
Make 2 of these and slip it over the piston shft. I would use tie wraps to hold the spring in place on the compression tool just as a safety precaution.
Old Jan 17, 2007 | 10:33 AM
Roadrider18
Went to a friend's machine shop to disassemble a '99 LowRider's coil-over the first time. We wanted to measure the tension (psi) on the coil before releasing so we could compress to the same psi upon reassembly. I guess you could measure coil length distance and get in the ballpark when reassmebling.
Old Jan 17, 2007 | 04:05 PM
speed8988's Avatar
speed8988
I went the local HD dealer and they wanted $79 to remove them take what 15 minutes at the most and my spring compressor for car spring it too big for those little springs. I figured hell for what Harley wants to remove and put back once powder coated I cound have a set of progessive for $20 more. I hate the HD dealer a bunch of ******.
Old Jan 17, 2007 | 05:31 PM
piniongear's Avatar
piniongear
Yeah and that's why I keep harping......screw those dealers and do it yourself. Hey, if it cost you even money to make your own tool and do it yourself you are still way ahead.
You have freed yourself from the talons of the greedy dealer, and you do not need his help (nor the expense that accompanies it)
You can make your own compressor. I have made one for mine using steel plates and all thread rod, so it can be done. Forget going to a dealer and figure how you can do it yourself. Not only on this subject of shock spring removal, but everything else as well...........pg
Old Jan 17, 2007 | 09:42 PM
speed8988's Avatar
speed8988
ORIGINAL: piniongear
Piniongear you are right. I have the same idealogy as you. I'm going to my buddies in Daytona them weekend to get them powdercoated so I don't have lots of tome to make a tool but I will once I get back. I was one the way to my buddy's Auto shop which is a 40 min drive with traffic for him to do it hopefully using his set up. I thought to myself I pass a little Yamaha/susuki Dealer that sells mostly Dirt bikes and ATV's a small shop. I turned around and see if I could try my luck. The service guy took my shocks and went to the Tech (1 tech shop) and he did for me real quick I asked what I owed and he said, "Just tip the Tech." I gave him a $20 and told him I would be back to to have him re-install the springs on Tuesday. I remember when the harley dealer used to be like this...Back in the 80's. While I was only a kid like 5 or 6 I remember my father taking his carb to his sportster to the dealer and they would help him with tips or advice on how to fix. Always had issues so I remember going there alot. Those days are long gone for Harley and it's a shame that when I walk into a HD dealership they act as if they are selling Ferrari's. My bike only has 500 miles on it and it's completely taken apart so I can powder coat stuff and my neighbors are amased how I took apart a new bike and ask how do you know how to do this. While a lot times I have never done the tasks before unlike many other I'm not afraid to give it a try. So now I'm off to post some posts about thing I need help with
Old Jan 17, 2007 | 11:04 PM
piniongear's Avatar
piniongear
Good for you Speed. That was a good idea of stopping in at a dirt bike dealer. Other members should remember to do the same when they need a simple task done with a tool they do not have. Cheaper than any HD dealer! The results of your effort were a reminder of how the HD shops once were. Those days are gone forever, now it's just a big greedy business enterprise.
Give you an example: Several years ago a new Harley dealer came to Houston TX. The shop was built brand new in this huge two story building alongside a major freeway. Since I have been riding since 1957 (wow, 50 years now) and lived in Houston all that time I do know a little bit about the history of the shops that have come and gone.
Anyway I went into this new dealer when he just opened and struck up a conversation with a couple of the brand new employees who were bending over backward to please. That has since changed, by the way. I was curious who the owner was and how he obtained a franchise, how was this owner connected with motorcycles etc.
What I found out was this guy owned all of the GNC stores on the upper West Coast before the dealership. He lived in the Northwest, sold the GNC and bought the Harley franchise, moved to Texas, and set up shop, so to speak. Had nothing to do with motorcycles previously. He is just another business man. And a greedy one at that.
His dealership looked like he had an inside line direct to the factory by looking at all the goo-gaws hanging on the wall. All these people are in there buying this stuff right and left, along with the motorcycles he had floor planned on the showroom, which were many.
Well, you can't go back into the shop. even if your machine is being worked on. You can get no help unless you buy it for $80 per hour. Ya-da, ya-da, ya-da.
I can well remember during the 1960's when Harry Stelter, the owner of Houston's original Harley Davidson dealership would loan me tools from the Stelter Harley Davidson Shop to take home and use on Sunday and Monday to work on my own bike, with the only stipulation that I be there to return them when he opened on Tuesday morning. I of course never failed to do that.
Can you imagine such customer service today? Never happen. These dealers are nothing but big business today and I say....
Screw them, up close and personal..........pg
