air filter
Old Jul 24, 2012 | 02:00 PM
jojo2dog's Avatar
jojo2dog
Default air filter
any reason I can"t use a screaming eagle backing plate with a k@n filter and the hardware from my intake system to install a round air filter on a 2008 fxd
Old Jul 24, 2012 | 02:15 PM
visualj's Avatar
visualj
Not sure about the new ones, but I did that on my 99 FXDL. I did have to use longer bolts through the filter to the backing plate, the stock ones are about 1/4" too short. IIRC, they are 1/4" bolts. Can't remember the length.
Old Jul 24, 2012 | 04:24 PM
Squirrel67's Avatar
Squirrel67
I used a k&n on a screaming eagle backing plate. Part # for the round k&n filter is #0800, it was a direct replacement for the SE filter.
Old Jul 24, 2012 | 05:24 PM
jram67's Avatar
jram67
The old hardware won't work, you need 3 new bolts and 2 new breather tubes. You also need a couple of o-rings for the backing plate. I just did this mod, I found the part numbers on a post here. I did reuse my 2 breather tube screws and the backing plate gasket.
3 ea studs 29447-99a
2 ea tubes 29557-05
3 ea screw 3938
2 ea o-ring 11292
giacomo56
Milwaukee Eight (M8)
14
May 12, 2018 11:36 PM
blueangel73
Sep 9, 2016 06:13 PM
El Chiguete
Sep 9, 2016 08:19 AM
cpracing519
Jun 6, 2011 07:38 PM
Brigger
Apr 4, 2008 06:30 AM
