FINALLY!!! Got my IPB Race pulled...
Old Jul 24, 2012 | 09:50 PM
PKellyMc's Avatar
PKellyMc
From: PacNW; Beacon of Conservatism in a Sea of Liberals.......AZ Snowbird; Just another Conservative
Talking FINALLY!!! Got my IPB Race pulled...
Well, it took a week and a day, but I rec'd the Jim's IPB Puller Plate in the mail yesterday. I had the other Puller Tools, so I only ordered the magic plate ($44). Today was the day and after a quick run to FastenAll for 2 Grade-8 3/8"x6" bolts, I tackled the Race...
The Jim's tool
My puller beam and driver bolt
The set-up; pipe-wrench braced on pax peg to hold puller beam, 18" breaker bar with 5/8" socket to drive puller bolt
Another view of same
Close-up of Jim's tool engaging the race
Reward after agonizing & exerting effort
I was almost sure something was gonna break, as much weight I was applying to that breaker bar. I even pre-heated the race with a propane torch, in case it was Loc-Tite'd in place. That later picture DOES look red where the race sat on the shaft.
I know many guys have used a cutting wheel to score the race, then split it with a chisel; that was my fall-back position. I'm glad the Jim's tool had the gumption to handle the abuse. Two of the puller fingers of my K-D Tools Kit sheared when I tried them last week.
Yeah, replacing the stock IPB with the Baker High-Torque. Already tested it and it slip-fits onto the input shaft real nice. Spent the rest of the day with Simple Green and several brushes. Should start reassembly tomorrow.
Old Jul 24, 2012 | 11:48 PM
ackman1968's Avatar
ackman1968
Good deal my friend! So will the Dyna get the nod in August or are you bringing a bagger?
Old Jul 25, 2012 | 12:02 AM
Mascman's Avatar
Mascman
The tool seems overkill.
I brought my air die-grinder home from work, but when I tried to get it in there, i saw it was too big and there was no way I could cut the race with it.
I decided to try my dremel with that tiny little cutting wheel since I didn't have anything else around...it sliced right through it in a couple minutes. It was a pleasant surprise to me!
Old Jul 25, 2012 | 01:09 AM
PKellyMc's Avatar
PKellyMc
Yeah, Rick. I'll get the Wide reassembled and wring it out a bit before we head to Sturgis next Friday...will stretch the Sturgis trip into Goldendale, where we'll be arriving from the south this year, instead of the north.
After this experience, I may be recommending the Dremel with a small diameter wheel. Your way sure sounds like a breeze compared to time/tools/stress of my pull.
Old Jul 25, 2012 | 01:48 AM
kk6pg's Avatar
kk6pg
The only time I use the puller is on the rare occasion I need to save the race. Cutting it off is a whole lot easier.
plongson
2014-2024 Touring Models
23
Mar 10, 2019 07:07 PM
CGLTD
Aug 13, 2013 08:26 PM
gnafin
EVO
13
Apr 1, 2010 09:52 AM
