My 10 dwg has stage 1 intake gutted cats and drilled baffles. It has pcv on it. It has ran good for 2 weeks in this configuration. Today I took a short ride and shut the bike off. Went to fire it up five minutes later and killed the battery trying to restart it. I jump started it and rode it back home (rather spiritedly) and it ran fine. Later on in the day I went to go for another ride and it fired right up but started missing badly.
I have
- fully charged the battery and verified the voltage
- swapped plugs
- checked battery terminals
- checked plug wires
- checked fuses
- swapped pc maps several times
did you check your power commander connections for moisture? washed your bike lately?
Just got back from a ride and seen this. You nailed it! I washed it this morning. It's wierd that it ran fine for a couple of hours after the wash. I got desperate and was going to try unhooking the pc completely when I discovered a TON of water in the connector.
Once the contacts are clean and dry its fine to just put some ordinary cheap grease or vaseline around plugs and sockets as water-resistant packing to prevent water getting in again.
