cams / big bore kit
Old Aug 6, 2012 | 09:56 PM
fatjeff's Avatar
fatjeff
Default cams / big bore kit
I was wanting to do cams on my 2011 fat bob. My bike guy said that most likely the crank shift will have run out and need to be replaced costing close to 3k or more. Then we started talking about my options from there he said we could go to a 106 or 117 s&s. But I have a hard time changing out the motor at only 25k miles on it. I wanted to see what others have done and what to expect from cost to experiences. Also some one was saying they thought that going to a 117 would destroy the frame belt and other things ( I think is a load of mularky).
Any input from experiences is great.
Thank you for you're time
Jeff
Old Aug 6, 2012 | 10:14 PM
02fx4dude's Avatar
02fx4dude
I think I would find a new bike guy.
As far as I know, crank run out is only an issue if you're looking to install cams with gear drive, which I don't see anyone do on the 96 or 103.
PS - I did my cam swap for about $650, that included cams, gasket kit, adjustable pushrods, bearings and bearing remover/installer tool.
Old Aug 6, 2012 | 10:25 PM
Tat2u's Avatar
Tat2u
he's jumping the gun a bit there, check the runout but its more than likely fine
Old Aug 6, 2012 | 10:32 PM
QC's Avatar
QC
Put in a call to Jamie at FuelMoto or Scott at Hillside. Both sponsors in here. I have talked to both- straight shooters.
Old Aug 6, 2012 | 10:33 PM
Thingfish's Avatar
Thingfish
+1 on getting a new bike guy. His answer sounds uninformed and way out of bounds.
Old Aug 7, 2012 | 06:06 AM
fatjeff's Avatar
fatjeff
This is what he had originality quoted me 700 to maybe a 1000. Which I'm okay with I don't want to do the big bore kit just yet. Thanks guys his never done anything shady to this point a miss communication I hope.
Old Aug 7, 2012 | 06:53 AM
Good_Apollo's Avatar
Good_Apollo
Yeah, unless you plan on going gear drive you should be fine. All of the Twinks past 02 have more run-out issues if trying to go gear driven.
Old Aug 7, 2012 | 09:49 AM
07bobber's Avatar
07bobber
wow! time to get a new bike guy, this guys feeding you BS to give him some work...
Old Aug 7, 2012 | 12:08 PM
Knucklehead15's Avatar
Knucklehead15
I am sold on the gear cams and the big bore. I have a 06 fxd I'm doing crank 4 3/8" (trued and welded), 106 s&s kit, 585g EZ, and primo clutch. So far in parts I have 2260.
Old Aug 7, 2012 | 01:33 PM
Good_Apollo
Well since you are splitting your cases anyway to do a stroker the cost for a true and welded crankshaft makes a lot of sense once you are that far in. Sounds like it will be a screamer!
