To pre-load shift, or not?
Old Aug 7, 2012 | 08:02 PM
TORQUEY's Avatar
TORQUEY
Originally Posted by patrickd
You guys talking about shifting without using the clutch right?
NO
Originally Posted by overhead
Nah, I think they are talking about putting upward pressure on the gear shift prior to actually shifting.
YES
Originally Posted by 01ragtop
No. Preloading the shifter is when you put slight pressure on the shifter lever in anticipation of an up shift. With that pressure on the shifter and under acceleration, a quick grab and release of the clutch makes for smooth quick shifts. Well on my zx7r it does. On my wide glide it just sounds painful. I think the transmissions are too loose and the bikes too heavy to make this the ideal way to shift a Harley.
YES
Originally Posted by SteveO-ll
Flat shifting..............you got it.
When RPM's and speed are in-sync it is supposed to give smooth shift without clutching.
Hard on drive train unless beefed up to handle it, as other poster (axslingerw) stated.
NO
Are we all together now?
Old Aug 7, 2012 | 08:06 PM
overhead's Avatar
overhead
Originally Posted by TORQUEY
NO
No. Wait, errr, yes. No, no, no, I mean...
Yes
Old Aug 7, 2012 | 08:23 PM
hboat's Avatar
hboat
What a group. Ya'alls make me laugh...
Old Aug 7, 2012 | 08:29 PM
cacolade's Avatar
cacolade
i was going to chime in but nevermind.....
Old Aug 7, 2012 | 08:48 PM
dirtdreamer50's Avatar
dirtdreamer50
OK, I'll join in to this mess. I agree that Harley transmissions do not like to be preloaded. Had a few metric bikes, adventure style, that required preloading to keep from mis-shifting.
As to clutchless shifting, it works great up and down, on Harleys, as long as the shifting rpm is around 4k or higher. Proper throttle control before and after the shift is needed to be smooth, too. Normally I use the clutch on the Dyna, because I am shifting at lower rpms and clutchless shifitng at those rpms are definitely not smooth.
So. preload: NO
clutchless shifting: YES
harmful to trans: NO
clutched shifting is smoother but normally a slower shift: YES
Back to the fun... tomp dd50
Old Aug 7, 2012 | 08:50 PM
FXDWG12's Avatar
FXDWG12
YES
Thanks TORQUEY. Figures a sport bike rider would know. Wow, I didn't know that I was doing any fancy trick ridin stuff. This is how I was taught to shift. This method actually makes shifting easier. Like was mentioned earlier. Just apply a little upward pressure on the shift peg just before the shift. Then, with just a gentle squeeze of the clutch, the bike will shift itself just as soon as the shift dogs release. I guess if the WG doesn't like it though, I'll just have to revert back to the "pull, shift, release" method.
Thanks Guys for the replies.
Old Aug 7, 2012 | 08:54 PM
len_atwork's Avatar
len_atwork
Seems to me that putting pressure on the shifter forks while at full RPMs might cause premature wear?? Maybe?
Old Aug 7, 2012 | 09:00 PM
TORQUEY's Avatar
TORQUEY
I think most would recommend VERY LIGHT pressure. I use this technique, and all is well. Largely though, I am very easy on my bike, riding almost always in a moderate RPM range, using positive, firm, but not forceful shifting.
Old Aug 7, 2012 | 10:09 PM
FXDWG12's Avatar
FXDWG12
Ya, slight pressure is all that is required. And, I'm no mechanic, but it was explained to me that nothing happens until the clutch lever is depressed far enough to cause the shift to happen. This is the same method used for speed shifting. Even though I have done it on accident. I usually try not to get my RPMs high enough to be consistent with that maneuver. And, I always pull the clutch anyway. I know that shifting becomes second nature once you have done it enough. But since I'll have to adjust my method, shifting is awkward currently.
Old Aug 7, 2012 | 10:16 PM
archergodwin's Avatar
archergodwin
I had a Yamaha SECA 750 back in '80... it's shifting can best be described as a sports car "snick" with preload and sometimes without clutch... Harley's shift is more like your 1960 chevy dump truck... get the rpms right, and shift it slow... with some good gear lube... works like a charm. .. that's if you're cruising... hitting it hard, it shift's alright.. not lightning.. but faster.
