To pre-load shift, or not?
Old Aug 8, 2012 | 09:58 AM
JCleary's Avatar
JCleary
I always put pressure on the lever on my BMW's. They didn't like to shift without it.
My other metrics, I preload and roll off the throttle to complete upshifts. No clutching necessary.
I tried both on the Harley, and they don't like it a bit. I pull in the clutch, shift, and release the clutch. The clutch I barely pull in though, just enough to allow some slip.
Old Aug 8, 2012 | 10:05 AM
harleyflyboy's Avatar
harleyflyboy
I feel dumb, I have been driving things that shift since 1957 or so and have never heard of pre-loading a shift. Sounds like extra effort, extra wear on the parts, and to save what........ .00003 milli seconds of shift time.
Old Aug 8, 2012 | 10:08 AM
Sharkman73's Avatar
Sharkman73
My bike doesn't like the pre-load method either. However, I can downshift without the clutch at all very smoothly if it's done correctly. I did this by accident on a loner bike once, so then I did some experimenting on it and figured out when to downshift without using the clutch. I don't do this normally, just wanted to see if it could be done.
Pre-loading makes shift times quicker on a metric sports bike, but it seems it's just hard on **** on a Harley & you don't gain anything.
Old Aug 8, 2012 | 10:17 AM
HBomb74's Avatar
HBomb74
I've never pre-loaded on my Harley. Just the loud clunk that you can hear and feel when dropping into first took me a while to get used to. I rode a Honda and two Suzuki sportbikes before my first cruiser and those transmissions felt like precision mechanical wonders compared to my Fat Bob. I don't ride my HD any where close to the way I rode those rice rockets. If I'm just farting around town usually it's a slow and deliberate roll of throttle, disengage clutch, shift, continue farting around....
Old Aug 8, 2012 | 10:45 AM
128auto's Avatar
128auto
Well I don't see any advantage doing that, however please don't try it on your car, you will wear out all the gear synchronizer rings in no time
Old Aug 8, 2012 | 11:56 AM
FXDWG12's Avatar
FXDWG12
Well there is actually no extra wear on anything when done correctly. And there are other reasons to using this method besides saving .00003 m/s.
Once again, Thanks for the constructive replies.
Old Aug 9, 2012 | 01:00 AM
harleyflyboy
What are the other reasons?
Old Aug 9, 2012 | 06:43 AM
GraemeR's Avatar
GraemeR
I suppose if your in racing mode then a pre-load shift could help keeps the revs up between gears, which is what you want for race shifting. BUT good luck trying it on a harley AND getting consistant results; the tranny is just not built for it (unless you install a proper electric or air shifter that interupts the Ign between shifts)
On my 250 street racer the ONLY time i used the clutch at all was at the lights to start...all my up and down shifts were always clutchless.
Old Aug 9, 2012 | 07:43 AM
BigGdawg's Avatar
BigGdawg
Originally Posted by overhead
I don't know anyone that pre-loads and shifts a bike without the clutch, I hope that is not what you guys are talking about.
That's the only thing that makes sense from the preceding discussion. A Harley does not use a preloaded shift unless you do it without the clutch because that's what happens.
Old Aug 9, 2012 | 09:40 AM
JCleary's Avatar
JCleary
On a metric, you can preload the shifter then roll off the throttle for a smooth clutchless shift. Some of the bikes I've had prefer this method to clutching.
On BMW's, preloading the shifter is almost mandatory. My 2002 K1200RS wouldn't complete a shift half the time without preload. My 2004 K1200GT was a little better, but it still wanted preload. Without preload sometimes you'd hit a false neutral. Quite often, actually.
On a Harley, preloading is a waste of time. So is trying to do a smooth clutchless upshift.
