Shocks again air vs normal
Old Dec 3, 2012 | 05:13 PM
  #31
p51bombay's Avatar
p51bombay
54320-97 - push fitting, 5/32 (2)
54536-09 - valve and airline asy, rr shock
Old Dec 3, 2012 | 06:50 PM
  #32
scooter1128's Avatar
scooter1128
or, instead of the air line kit, you can get schrader valves at napa
Old Dec 4, 2012 | 01:21 AM
  #33
ebeattie's Avatar
ebeattie
Schrader valves would be a good idea, but the problem is that you MUST get both shocks the same pressure exactly or the ride quality and handling will suffer.
Looks like the stock pressure valve keeps both shocks tied together and thus both shock pressure will always be equal.
Old Dec 4, 2012 | 05:14 AM
  #34
JohnnyC's Avatar
JohnnyC
When I changed mine I discovered the air line on my older bike was a different size. I considered the new lines and "T" but opted for individual valves and filling points.
I have to loosen my bags to get to each one. Only need to pump them up when loading up for a trip and it's just part of the bike's checkup before hitting the road, like tire pressure (which used to be fun to find the valves before I got my lift).
Good luck and I hope the outcome is right for you too.
Old Dec 4, 2012 | 12:08 PM
  #35
trip20's Avatar
trip20
This is a non-issue. The HD handpump or similar will have a guage. It's not hard to pump each one to the appropriate number. Also, you'll have less garbage running all over your bike (fittings, hoses...etc). Not to mention if you have an air shock with issues it will be easier to tell.
Don't worry about the ride quality or handling. That will suffer anyway.
Old Dec 4, 2012 | 03:19 PM
  #36
OldTyme's Avatar
OldTyme
I just used the schrader valves on mine..$5 @ Napa. Found a HD-like pump for $20 (you need one that won't lose pressure when releasing....the shocks are very touchy) Found a new set of take-off shocks on Craigslist for $40.( the 13 inch model)
As far as Trips post about ride quality & handling suffering...... I would say that's completely wrong, but everyone has their own opinion. IMO it's the best thing I've done with my bike.
Old Dec 11, 2012 | 11:03 AM
  #37
Fusion777's Avatar
Fusion777
I've read the spring rates are much softer on these touring take-offs than regular dyna shocks. Would this have an adverse affect specifically on handling? Touring seems like it would be positively affected, but for those of you with them installed how is the cornering/handling?
Old Dec 11, 2012 | 01:10 PM
  #38
trip20's Avatar
trip20
I found that high speed cornering (long sweepers coming on to the highway for example), the rear end felt like it was lumbering up and down and washing out. From a comfort perspective, when riding 1-up, it was a plush ride -- I just didn't think it was a good sport handling feel.
2-up riding wasn't good at all. I'm no expert but I think it has to do with the rear end geometry difference between Touring and Dyna. The Touring bikes have the rear shocks more vertical and more towards the rear of the bike. Whereas Dyna's have more of a forward lean to the shock and set more forward in front of the passenger. The shock is easier to compress kind of like a hand-held nut cracker where you put the nut closer to the pivot point to gain more leverage. The shocks compress easier for the same reason.
All supposition on my part. Either way, I ditched them after a season.
Old Dec 11, 2012 | 06:08 PM
  #39
Fusion777's Avatar
Fusion777
Thanks. This is exactly the concern I had
Old Dec 11, 2012 | 06:35 PM
  #40
p51bombay's Avatar
p51bombay
Sounds like the ones you had may be suspect of low/uneven oil level or worn out. I've found just the opposite, I ride twisties all the time and have found them to work quite well considering they belong on a bagger. The ride is smooth, controlled, generally does not bottom out (except on large, unexpected potholes or bumps) and for the most part they handle what I throw at them without complaint and have yet to do anything bad handling wise. While these are not Ohlins, they do work pretty well, especially when you consider the price point. I usually run about 25psi.
byronk
Oct 14, 2016 07:20 AM
slim_powers
Oct 13, 2015 09:19 AM
Maricopa Mike
Nov 25, 2013 11:42 AM
atrain68
Mar 7, 2010 12:27 AM
2002 Classic
Jan 5, 2009 11:42 PM
