Questions about engine
Old Aug 12, 2012 | 10:39 AM
Canes's Avatar
Canes
6th Gear
Default Questions about engine
Ok i am a new Harley rider (v-twin noob) and i bought a 99 FXDX with some mods. The dealer couldnt tell me anything so maybe some of you can. I will post some pictures and see whats what.
located on bottom of heads no idea what the emblem is?
Whats this blue button?
Old Aug 12, 2012 | 10:47 AM
thedonthere's Avatar
thedonthere
blue buttons are compression releases and the stamp on the bottom of your CYLINDERS not your heads is most likely from the machinist who bored the cylinders. You may have something there............
Old Aug 12, 2012 | 10:52 AM
weekender2098's Avatar
weekender2098
thedonthere is correct.
Old Aug 12, 2012 | 10:54 AM
dyna rider's Avatar
dyna rider
Default Fxdx
Aside from the cowbell horn cover being tilted forward, it would seem to have high compression pistons installed. When you push down on the blue buttons, you should hear a click. You do this before you start the engine,each time, to make it easier on the starter motor.
I agree with the prior post about the machinist marks.
Old Aug 12, 2012 | 11:00 AM
Bone11B's Avatar
Bone11B
What ever you do dont push that blue button!
Old Aug 12, 2012 | 11:01 AM
Bone11B's Avatar
Bone11B
Just kidding they are manual compression releases and that is some Zippers Big Bore Cylinder Kit.
Old Aug 12, 2012 | 11:19 AM
Canes's Avatar
Canes
6th Gear
Wow guys thanks for the quick response. Now just need to figure out what size the previous owner took the Zippers cylinder and heads to.
Dyna Rider which chapter you with?
Old Aug 12, 2012 | 12:47 PM
misfitJason's Avatar
misfitJason
They are zippers cylinders with hi comp pistons more than likely
Old Aug 12, 2012 | 02:10 PM
Robtarra39's Avatar
Robtarra39
Most likely a 95 inch big bore kit with high compression pistons, bet it sounds real nice and throaty
Old Aug 12, 2012 | 02:39 PM
bigdaddy33's Avatar
bigdaddy33
The bike may have a 107" Zippers kit. They use compression releases in the 107".
http://zippersperformance.com/catalo...=862&prod=1556
If that's what you have, it's a real nice set up.
bigpete1
Dyna Parts
Dec 28, 2017 05:32 PM
Pa-Rider
Mar 22, 2014 04:57 AM
redrubicon2004
Sep 29, 2013 02:22 AM
cpc0812
Softail Parts
Oct 13, 2012 07:26 AM
detonator
Sep 3, 2007 01:40 AM
