True Track initial impressions
Old Aug 19, 2012 | 03:27 PM
  #31
Denny69's Avatar
Denny69
Originally Posted by clayman
I can induce the effect if i push the handle bars back and forth while riding. Does this sound like an issue the true track will take care of? Thanks
Sounds like something a 'wrench' will take care of.
Old Aug 19, 2012 | 04:42 PM
  #32
clayman's Avatar
clayman
Ive gone over everything i can think of and that i have read in different posts.
Old Aug 21, 2012 | 12:28 AM
  #33
oldlefty's Avatar
oldlefty
Trying to figure the wobble i got on mine out as well. 2010 wide glide, lowered front and back. Seems when i accelerate hard or if i hit a dip in the road or going into a corner fast the front end will start wobbling back and forth. Not sure if its the narrow front tire or what. I can induce the same effect if i push the handle bars back and forth while riding. Does this sound like an issue the true track will take care of? Thanks
i am not sure if the handle bar movement and the wobble are the same prob or two in one. true track sounds like most of the answer for the high speed wobble from what i can tell. i installed a TT on my ol 08' FLHX and it took most of the wobble out. the dyna set up is totally different beast. i cant wait to see what a difference it makes on my dyna.
as far as the bar thing..... have a good mechanic look at your front end homie. maybe something is loose or something not right in your lowering kit maybe? running a fork brace above fender will stiffen up that wide glide also.
hope that helps any.
Webo
Jan 20, 2015 04:09 AM
Hessmonster
Dec 13, 2013 10:54 AM
Gliden
Jul 2, 2012 06:38 PM
stevepacman
Jan 7, 2012 06:48 AM
jakblu
Nov 21, 2006 03:08 PM
