Combination Digital Speedometer/Analog Tachometer - 4" for 04-11 Dynas
Old Aug 25, 2012 | 01:49 PM
  #61
MrElectric03's Avatar
MrElectric03
For those that have bought this already...
Is the chrome ring removable? I like the gauge and like that it has the fuel level feature but by the time I buy the sender for the sportster Ill have about the same amount as the Dakota Digital gauge. Chrome will look like crap on my bike im just wondering if it can be removed and painted. Thanks!
Old Aug 25, 2012 | 01:52 PM
  #62
FXD_TG's Avatar
FXD_TG
Originally Posted by MrElectric03
For those that have bought this already...Is the chrome ring removable?
I don't believe so. It appears to be an integral part of the assembly.
Old Aug 25, 2012 | 01:54 PM
  #63
MrElectric03
Alright so id need to mask it off, good deal. Thanks very much!
Old Aug 25, 2012 | 01:55 PM
  #64
Scaredofrain's Avatar
Scaredofrain
Saw one at the dealer today as a display model on the counter. It had an enclosure on the side with a push button. Snazzy looking although at first I thought the whole thing was like a HD branded alarm clock.
Old Aug 26, 2012 | 12:40 PM
  #65
GoGetter5832's Avatar
GoGetter5832
My tank just happened to be full, so I haven't done anything with the fuel indicator. I figure it will get itself sorted out in a couple hundred miles. In the mean time, I'll continue to rely on my analog gauge and odometer.
Fuel Indicator and everything else seems to be working fine. Just took it for a spin today. I just have ONE MORE QUESTION for you. When I filled up I reset my "Trip A" to "0" miles and tried resetting my "Trip B" to zero miles as well. For some reason it is not letting me reset my "Trip B." I've basically tried everything and it will not reset. Have you had the same problem? Thanks!
Old Aug 26, 2012 | 12:46 PM
  #66
p51bombay's Avatar
p51bombay
That is the countdown when you install it, you have 31.8 miles or something like that to make sure it works correctly before it locks to your ecm, once it counts down to zero it will work normally.
I just posted a report on how my new one is working.
Old Aug 26, 2012 | 01:08 PM
  #67
GoGetter5832
You are the man.....thanks bro!
Old Aug 26, 2012 | 02:37 PM
  #68
mattVA's Avatar
mattVA
I have a question: Everyone so far has mounted this in their dash and the trip reset button is on the console. .what about mounting it on your bars, how would you use the trip reset. .? I know normally FXD/Sportster mounted gauges have a trip reset button on the back of the speedo itself. .does this one?
Old Aug 26, 2012 | 03:14 PM
  #69
GoGetter5832
As far as I can tell this one does not have a trip/reset button on the back
Old Aug 26, 2012 | 03:46 PM
  #70
mattVA's Avatar
mattVA
I figured it out. The switch is just hanging from the wiring harness that plugs into the speedo, so it can be mounted anywhere.
