Tower Gasket
Old Aug 21, 2012 | 12:03 PM
BigDaddyMongo's Avatar
BigDaddyMongo
Default Tower Gasket
I just changed my tower gasket last year and noticed its leaking again! Does anybody have any insight as to why its leaking again after having a new one installed last year?
Old Aug 21, 2012 | 05:18 PM
SuperFastGlide's Avatar
SuperFastGlide
if your not running mid controls it will continue to slip or shift out of position and cause a leak as there is no shifter shaft running thru the tower... i solved my problems with this by removing my outer primary and plugging the holes with 9/16s freeze plugs from napa..
Old Aug 21, 2012 | 09:57 PM
BigDaddyMongo
I'm running mid controls.
Old Aug 22, 2012 | 12:48 AM
onemyndseye's Avatar
onemyndseye
Im about to change mine too bro.. coming up on a year of ownership. Its a 09 FXD. It should be warranty I guess but I'll probably do it myself so I can strip/polish the outer primary.
Seems easy enough to change...?
Old Aug 22, 2012 | 06:20 PM
BigDaddyMongo
Oh yeah its a piece of cake to change, I just want to know what and why is it leaking again!!
Old Aug 22, 2012 | 09:14 PM
cmancini26's Avatar
cmancini26
Had mine changed 3 times under warranty finally git to the point where the dealer had different techs mic the crank case and found lil valleys going through it so moco warrantied it they claimed it as a "milling problem"
Deerslayer011
Jun 26, 2016 08:48 AM
R-Jay
Jun 27, 2012 07:32 AM
APEDnLOW
Jun 11, 2012 10:42 PM
matts Dyna
Jul 23, 2011 12:48 PM
splitting_lanes
May 27, 2008 08:52 AM
