Why am I blowing tail lights?
Old Aug 24, 2012 | 12:47 PM
JHL-ShinySideUp's Avatar
JHL-ShinySideUp
Default Why am I blowing tail lights?
2011 FXDWG
I bought it in May 2012 with 9500 miles on it. In the 3 months/3500 miles since, I've replaced the right rear tail light three times.
It's only the turn/brake filament that's burning up. And it does look burnt, not simply broken/shaken loose. I know QC on 1157 bulbs is probably not terribly stringent, but still.
It's not like it's happening right after I ride in the rain, or after I hit a particularly nasty railroad crossing.
All other lights and (as far as I can tell) all other electrics work fine.
A couple of weeks ago I relocated my turn signals and license plate with the Great Bike Gear bracket, and in the process I pulled and checked the wiring and connections on both sides - no breaks, rubs, or kinks in the wires.
So ... something wrong?
Normal for a rumbly Harley to shake stuff loose?
And would an LED run/turn/brake conversion solve this?
Old Aug 24, 2012 | 12:53 PM
Stag556's Avatar
Stag556
I had this problem and the dealer warrantied the bulbs. They said there was an issue with recent bulbs the Harley made.
Old Aug 24, 2012 | 01:01 PM
JHL-ShinySideUp
I'm on the fourth bulb now, and the last 3 have come from Advance Auto Parts.
Should I really buy HD bulbs? I think not.
Old Aug 24, 2012 | 01:06 PM
Foxster's Avatar
Foxster
Usually blowing bulbs when its just one bulb is down to a poor contact, either a loose connector or the bulb socket.
Old Aug 24, 2012 | 01:09 PM
Hogpro's Avatar
Hogpro
Former Sponsor
Have you checked the wiring harness under the fender? Maybe the wire for the brake light is frayed and grounding out?
Old Aug 24, 2012 | 01:20 PM
j2m's Avatar
j2m
Same thing happened to me. Went through about 8 bulbs, every brand I could get a hold of. Very frustrating!! I switched to the Run-Brake-Turn LED strip last week
Old Aug 24, 2012 | 01:31 PM
JHL-ShinySideUp
I haven't pulled the bulb socket out and checked it yet. I'll hit that tonight.
Nope - I checked the wires end-to-end when I moved the signals and license plate.
Pics of your lights from the back? What brand/where did you get them?
Old Aug 24, 2012 | 01:43 PM
j2m's Avatar
j2m
I got it from Chromeglow http://www.chromeglow.com/catalog.as...showprevnext=1
I went with 11" and it is a good length for my rear fender.
The run/brake splits in half for the amber turn signal
Old Aug 24, 2012 | 01:58 PM
Scaredofrain's Avatar
Scaredofrain
Did you buy a motorcycle specific bulb? My guess is that you picked up a standard car bulb. The bike ones have more support arms on the filament avoiding breakage.
Old Aug 24, 2012 | 01:59 PM
Scaredofrain
I think you should!!!!
