I saw these brackets for my WG on ebay and they seem simple enough to install. http://www.ebay.com/itm/KURYAKYN-49m...430a34&vxp=mtr
For those of you that have done this mod: As far as the wiring goes, how did you wire it cleanly from the handle bar. I asked a vendor if i needed to extend the wires and he told me that i needed less wiring . Thanks for the info in advance.
I just installed LED fork wrap arounds on my WG.
All you have to do is cut the existing turn signal wires, from the handle bars and tap into the turn signal wiring harness hidden inside the front of the frame (in front of the gas tank)
If you remove the plastic cover underneath the tank and pull the wires out you will find 2 empty connectors for the front turn signals. Then I just cut the connectors off and soldered and heat shrink the connections. Fast and easy.
The hardest part was trying to figure out why the hell the turn signal wires are not running through the handlebars...
