Help with Dyna issue?
Old Aug 26, 2012 | 04:46 PM
randall968@gmail.com's Avatar
Stage II
Default Help with Dyna issue?
Hello all, My name is Bobby and I'm a first time poster
I recently bought my first Harley, 2000 Dyna Glide Lowrider. I love it. Im a taller guy and recently bought forward controls to put on the bike. I installed them myself and the installation went very well. My problem:
After I was done, I lost my rear running lights. The rear turn signals still work, but they don't illuminate as running lights, only when activated. My brake light will not illuminate at all, not when using either the front or rear brake. During installation of my forward controls I used only an "extension kit" , I never touched anything electrical. I checked bulbs and fuses and everything is in order, does anybody have any ideas? thank you all for your time and response,
Bobby
Old Aug 26, 2012 | 06:31 PM
AFMM3's Avatar
AFMM3
Unless the previous owner installed the "Run/Turn/Brake Signal Module", the rear blinkers do not illuminate during normal operation or during braking. They are just blinkers, so you may not have a problem after all.
Now they brake light not lighting up is a major safety issue. If the fuses and bulbs are good, the previously mentioned "Run/Turn/Brake Signal Module" may have been installed and is now bad. If the module doesn't exist, then you may have to get a meter and test for voltage at the bulb. Also make sure all the cables plugged into the tail light assembly are secure and clean.
Good luck...............
Old Aug 26, 2012 | 07:51 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
Remove your seat and check all the plugs under the seat to make sure they are connected. I think the light failure is just coincidental
pak7176
Oct 24, 2017 07:59 PM
Dfszme
Mar 11, 2017 11:25 AM
jjaacooper
Mar 22, 2012 09:57 PM
PriestFan
Aug 2, 2007 07:09 AM
PriestFan
Jan 3, 2007 10:52 PM
