Bike sputtering
Old Aug 28, 2012 | 04:57 PM
Smoots's Avatar
Smoots
Default Bike sputtering
Hi I have an 07 SB that I just picked up about a month ago, lately I've noticed at lower speeds, low gears that it kind of sputters/misses not sure how exactly explain it when I keep throttle steady, any ideas what it could be?
Old Aug 28, 2012 | 05:00 PM
RoadLord's Avatar
RoadLord
Check your battery connection... I know it sounds silly but it's EFI and if that negative cable is even slightly loose it makes the bike cut in and out... personal experience after a few negative post meltdowns... my SB was notorious for shaking the battery terminal fasteners loose!
Old Aug 28, 2012 | 05:07 PM
Smoots's Avatar
Smoots
I'll check that, thanks
Old Aug 28, 2012 | 05:14 PM
wtb3886's Avatar
wtb3886
In order to be of any help what is the setup of your bike, bone stock, pipes, stock or changed, breather stock or changed, power commander or not?
Any resent changes to your bike?
Old Aug 28, 2012 | 05:16 PM
Smoots's Avatar
Smoots
Stock except for forward controls, and just put on V&H slip ons with big city thunder monster baffles. But the bike started doing this before putting the slip ons
Old Aug 28, 2012 | 05:19 PM
RoadLord's Avatar
RoadLord
Try the simplest thing first and if that doesn't yield any results by all means come back and post away. I just had this experience with my 2007 SB and finally just got tired of it backing the damn negative cable out and I changed that thing twice! Now I'm much happier with my Switchback:-)
Old Aug 28, 2012 | 06:01 PM
Smoots's Avatar
Smoots
So I checked battery connections and everything looks good
Old Aug 28, 2012 | 06:10 PM
2011FXDC's Avatar
2011FXDC
I think you may be describing some low speed surging. If so it's normal. At slow speeds and steady throttle mine will surge a little.
Old Aug 28, 2012 | 09:14 PM
nevil's Avatar
nevil
Mine ran the same way until I put a tuner on it. The surging was annoying, not the reason for the tuner, and getting it to run smoother was an added bonus to the power increase.
Old Aug 29, 2012 | 08:13 AM
Smoots's Avatar
Smoots
Surging is a good way of descibing it, I do have some xied's on the way maybe that will help.
