FXD Handlebar Swap
Old Aug 29, 2012 | 08:05 PM
Roboy's Avatar
Roboy
Stage II
Default FXD Handlebar Swap
I have an 05 FXD and I'd like to give it a different look with some higher bars. Can anyone tell me how much higher than stock I can go without getting into swapping cables, wiring, etc? any help is appreciated.
Old Aug 29, 2012 | 08:11 PM
Inkdwheels's Avatar
Inkdwheels
I have an '08 FXD. I was able to run narrow 10" Zbars without changing cables. And now I'm running 7.5" straight risers and a 2" rise wide drag bar with the same cables.
Old Aug 29, 2012 | 08:16 PM
Roboy's Avatar
Roboy
Stage II
That looks nice. Did you ditch the speedo?
Old Aug 29, 2012 | 09:10 PM
Inkdwheels's Avatar
Inkdwheels
Nope.
Old Aug 29, 2012 | 09:51 PM
snstiggy's Avatar
snstiggy
I put street bob bars on my FXD and had to change clutch and brake cables. No need to replace idle/ throttle cables.
Old Aug 29, 2012 | 09:55 PM
HD Bobber's Avatar
HD Bobber
Inkdwheels
The speedo relocal is sick! Is that Joker Machine?
Old Aug 29, 2012 | 10:00 PM
Inkdwheels's Avatar
Inkdwheels
Originally Posted by HD Bobber
Inkdwheels
I got the bracket for the speedo from eBay. It's marketed for a sportster. The standoff is a piece of stainless spacer stock from work that I drilled and tapped. I just used a longer bolt for the tank. The forks just clear at full turn.
From the front.
Old Aug 29, 2012 | 11:07 PM
Bagger_Vance's Avatar
Bagger_Vance
I was just the opposite when I put on 10" Street Bob mini apes. I bent the brake line and re-routed the clutch cable but there was no way my idle and throttle cables were going to reach so I replaced those.
Old Aug 29, 2012 | 11:19 PM
snstiggy's Avatar
snstiggy
Mine is a 2005. I've read newer dynas have same issue you have. Because of the the different frame, 6 speed tranny you have cables and part numbers are different. 2005 Dyna will take the 2004 fxwg cables after a long search on how to make it work.
pheur
Apr 29, 2021 04:11 PM
Mountaineer Rider
Mar 18, 2020 03:10 PM
XjldX
Jul 26, 2012 09:41 PM
j88j
Oct 19, 2010 06:28 PM
DynaRyda06
Jul 18, 2010 10:36 PM
