Lighter Wheels
Old Sep 6, 2012 | 10:39 AM
sharkey's Avatar
sharkey
As I did on my FXDXT, I will probably go with 4.25X18 or X17 wheels on my FXDF...much better selection of tires. If the fat sidewall can flex enough to soften the ride appreciably, then it's gotta screw the handling royally. PM wheels are light and strong, but kinda "pimpy" looking for my tastes.
Old Sep 6, 2012 | 10:59 AM
crash1369's Avatar
crash1369
Yeah this is why I can't decide on anything. One of the things I like about the Fat Bob was the small wheels with the fat tires, and why I was leaning towards the stock size wheels. But I also didn't have any cares about handling when I bought it and now seeing how well it can I wouldn't mind taking advantage of that you know.
Old Sep 9, 2012 | 02:06 PM
Broken Wing's Avatar
Broken Wing
Changing to 17s will change the trail slightly on a FB. But the bigger difference will be the TYPE of available tires.
17 inch is considered primarily a road racing wheel size. This means most all (if not all) 17" tires are Z rated (soft compound, more flex, larger footprint, lower fuel mileage, more expensive, and far less tire mileage.) There are very few, if any 17" choices that are not Z rated.
Worth considering before making such an expensive decision.
Old Sep 9, 2012 | 02:14 PM
Broken Wing
Results for 16 inch wheels from Google Shopper.
Old Sep 9, 2012 | 02:45 PM
crash1369's Avatar
crash1369
Thanks a lot, this is the sort of information I was trying to find. To clairify if the overall size of the wheel and tire combination stays the same then the trail shouldn't change right, it's the overall size not the wheel size that would change it right?
Would 18" wheels offer a better selection of tires then?
Old Sep 9, 2012 | 03:28 PM
spankdog's Avatar
spankdog
Im going with 18s on my Fat Bob. Not too big but still looks and handles well. And there are plenty of tire options out there. BTW Crash, your screen name seems really familiar. You on any other forums?
Old Sep 9, 2012 | 05:04 PM
crash1369's Avatar
crash1369
Yeah, I'm all over place chances are we've probably crossed pathes before.
Old Sep 9, 2012 | 05:05 PM
spankdog's Avatar
spankdog
DTX maybe?
Old Sep 9, 2012 | 05:22 PM
crash1369's Avatar
crash1369
Yeah that must be it.
Old Sep 9, 2012 | 11:04 PM
spankdog's Avatar
spankdog
Right on. Didnt realize you rode. Anyway, if you want to get new rims and keep the good handling of the FB then I would stick with a 16-18" rim. Personally I think 18s look the best and there are alot of different tire options. You can keep the overall diameter the same by choosing a lower profile tire and the lighter wheel and tire combo will improve your handling over the stock set up. If you go larger on the overall tire and wheel combo, your handling WILL suffer. How much depends on how big you go. Its just physics. Anyone who says it wont is full of ****. The more rotating mass you have, the more effort it takes to change direction. The less unsprung weight you have, the better and more responsive your suspension will perform. It will never handle like a sport bike ofcourse but the Fat Bob is arguably the best handling Dyna made. In general, wider tires do turn in slower. But it has more to do with the profile of the tire. Some wide tires have a flatter center section which takes more effort to get it lean over and fall into turns. Mostly this applies to rear tires. The stock front FB tire is pretty wide but if you look at it you can see it has a nicely rounded profile. That combined with a lack of rake allows the bikes to turn in nicely. So do your research before you pick a tire. I think people who are under the impression that lighter wheels are unstable are confusing "unstable" with quicker steering with less input.
