Lighter Wheels
Anyway moving on, they said the wheels in question are 23lbs. That's more than double the BST wheels, but about half the OEM wheels right? However I didn't specify a size when I asked, and they didn't offer one but I assume they are probably talking about 16" since I would assume the smallest wheel would be the lightest. Everybody's wheels seem to be 3.5"/ 5.5" wide though, I guess that must be a common size for somebody but if I stick with the stock size tires they are a 1/2" wider than the ideal width. Are there any pros or cons to a slightly wider wheel I'm not thinking of? Theoretically that would translate to a wider, but also flatter contact patch right? Realistically it's only ~1/4" though isn't it so I assume it's a negligible difference?
What about radial tires? They are lighter and grip better so they seem like the logical choice to upgrade, but the interwebz seem to think that may not be recommended. But as usual provide no real detail one way or the other, is there any reason I should stay with bias ply tires? Would the suspension be to soft or would I need to change anything? I'm not even sure if anybody makes radial tires in the OEM sizes but if I could find an 18" set that is close to the same overall size that would probably be a much better performance choice.
***Discuss***
Would 18" wheels offer a better selection of tires then?
I know we all feel it differently & yada yada but most riders probably wouldn't notice the trail difference at all. After repeated back to back comparison, (16s & 18s) the difference was very noticeable to me, but I felt it was mostly due to tire width.
Over freeway rain grooves, tar snakes, and botts dots at 85-95, the 16s were just flat out better in my opinion. In fact, they were so much better, it was the determining factor in my deciding on a Fat Bob.
Front 16" - 25.21"
Front 18" - 25.47"
Rear - 16 - 25.82"
Rear - 18 - 25.82"(180mm)
Rear - 18 - 26.79"(200mm)
I'm getting to the point where if I can't find what I'm looking for I'll just keep what I have but I'm sold on 16" wheels now
Somebody correct me if I'm wrong but I don't think there is any downside to radial tires (except perhaps the selection of performance types availability of sizes, at least Harley sizes)
Everything I can find says if it was designed for ___ tires there may be differences that could cause problems if you switched to the other type. I can understand the noncommittal warning but somebody has to know what would be different or dependent on a particular type of tire? If I knew the specific areas of concern I could decide how severe they really are or probably correct them if necessary.
I called the dealership, but the guy who answered sounded pretty confused. He said I could put any tire I wanted on but I got the impression he didn't really understand the question.
As for the tire size, I like how it rides now so I want to stay within the OEM specs... and I have no intention of cutting stuff to make 37's fit this time around
Sssssoooo much cutting to get those giant *** tires on
Front 16" - 25.21"
Front 18" - 25.47"
Rear - 16 - 25.82"
I assume the speedometer is dictated by the rear tire right, so if they are the same that's great. As for the front 0.26" probably isn't enough to notice
Are these what you are running now, what did you notice changed?
In theory at least the lower profile tires should be lighter and stiffer, plus I assume the wheels are lighter so all of that should translate into easier turn in.
If I am understanding broken wing though I believe he feels the 16" combination is much better for day to day real world driving though, I assume primarily due to the street manners and comfort right?
I place a very low priority on peg scraping my 700 lb, cast iron road pig through the twisties... 'cause I don't do that on this bike.
The shop was cool enough to let me test ride every bike I asked to ride. (2 of 'em twice!) It took me 2 weekends. I LOVED the 21" Wide Glide look, but hated the squirrelly front end at speed. The point is my input is really only aimed at those with similar priorities.
Damn that WG was purdy....
