Best tuner?
As long as the tuning device has the same tuning options as it's competitors,whether it's an inline
As long as the tuning device has the same tuning options as it's competitors,whether it's an inline like the pcv or a flash type like the screaming eagle model then they will all do the same thing. It's the guy doing the tuning that's the problem.
My 106 has 107hp/115tq. I get 50 mpg on the highway.
I'd look in to a different tuner,not tuning device
Take the bike elsewhere. 3 times with no other added mods is a joke. You are getting ripped off. I'd be in there complaining and getting it tuned for free. 3 times. Incompetent tuner,period,not the tuning devices fault the guy inputting the values is retarded
I have read up on it and it does look very good and I have only heard good things about it. They seem to have a big library of canned maps, much better than with the SEPST.
However, it is over-hyped by the makers. Yes, you can add wideband sensors and so run on closed-loop across all the range, but whether that translates into actual significant performance increases I'm dubious about. Its clearly nice that you maintain your tune in open loop with variable conditions but there's really little to suggest that is a big advantage. Most maps for tuners with narrowband sensors set the open loop areas to optimal AFRs (~12.0-13.0:1) and I just doubt that adding ECU control to this area adds much. I mean, there are very few wideband systems out there and there's a good reason for it.
I'm definitely dubious of their claims that it self-tunes. It doesn't, any more than any of the other tuners do. They say you can can swap out hardware, including cams, and it will adjust. Without something to measure power change (i.e. a dyno) no unit can retune a bike for hardware changes. Yes, it can get the AFR back to what it was previously, but whether that is still optimal for the new hardware is unknown unless you put the bike back on the dyno.
So, yup, I'm sure its great to use and all but I'm still open to persuasion that you are going to get a big difference (it has to be 5HP gain to wow me) between a good tune with it compared to, say, a PowerVision or SEPST if they are all dyno-tuned properly. Willing to be convinced though
And just for kicks since I have a Dakota digital that gives true 0-60 times I can also tell you that without any other changes when I swapped from a "tuned" PC III to the TMax I saw a change of -0.4 seconds in the 0-60 time.
To me that is significant. I would urge you to give it a whirl sometime.
The Tmax does not know a vital bit of information...whether the changes it or you make are improving the performance. Sure, the AFR will be accurate to what's in the map but you don't know this map is making best power without putting it on a dyno.
What, if anything, you do next is the difference between tuners. If its the tmax then it'll read the air-fuel ratio and tweak the settings so that the bike runs at the air-fuel ratios set in the map. With other tuners, like SEPST and Power Vision, you do a auto/smart tune to achieve a similar thing. The tmax saves a manual step and is worth it just for that.
If the map was good in the first place and the hardware it was created with was the same as you have fitted then you can call it job done. If the tuner doesn't come with a map for your setup or you want the best power you can get then its dyno time.
