installing mid controls
Old Sep 3, 2013 | 07:14 AM
convincor's Avatar
convincor
Default Consider boards??
As mentioned your 2012 WG came with forwards from factory therefore doesn't have the hole in the primary (inner or outer) for the shift shaft. So you would need to replace both.
Another option would be boards. Here there are two options. Board kit from HD who's is same as SwitchBack, or aftermarket which is exactly the same as the old (pre06) Dyna Defender (FXDP) boards with the exception they have a boss intricated for the forward shift shaft.
The SwitchBack boards mount further forward the the old style which you may not like.
I've got the old style on the wife's low rider and we both like position over the SB. SB boards are just as far forward as the forwards. FXDP boards are a compromise between mids and forwards. Perfect for our 5'5" height
Check out eBay # 380706718295
Old Sep 3, 2013 | 08:05 AM
FXD2003Rider's Avatar
FXD2003Rider
Administrator Emeritus
Originally Posted by chris h.
...If you have mid controls you have to take the shifter shaft out of the primary and cover the holes...
There is another options as well: shifter clip & shifter shaft cover...
Originally Posted by FXD2003Rider
Home made clip by forum member Keeg:
Here's the clip from the VTwin set:
And an image of the short (older) version from HD on my bike:
IMO it's not that hard to make one yourself...
From one of my older posts:
Cover, shifter shaft 34640-93 should fit....
Old Sep 3, 2013 | 08:16 AM
convincor's Avatar
convincor
OP is looking to install mids, not take them off.
Old Sep 3, 2013 | 09:52 AM
FXD2003Rider
I know and it has been made clear to him floorboards will not fit with his current pipes.
I was just responding to chris h.'s statement
Old Sep 3, 2013 | 10:12 AM
convincor's Avatar
convincor
Frame bracket for mids is in same place as rear for boards(old style). Brackets on SwitchBack move the boards about 2" forward.
Shifter on SwitchBack Is in same location as forwards. So if it's a reach now with forwards, still would be with SB boards.
JayOhh
Nov 1, 2013 03:10 AM
mizmazzle
Mar 3, 2011 08:18 PM
OhioSkully
May 9, 2008 07:10 AM
fireball
Apr 7, 2006 08:04 PM
