tool to remove tranny fill plug?
Old Sep 25, 2012 | 08:29 PM
FXDWG12's Avatar
FXDWG12
Originally Posted by brown dawg
i threw my stock one away and bout the one you can turn by hand
The plugs with the finger grips look cool. But they are hard to fit a torque wrench to.
Old Jun 11, 2016 | 08:09 PM
ndallmer's Avatar
ndallmer
6th Gear
Here is a good DIY if you don't have a 3/8" Allen/Hex key to wrench on your tranny plug. (It's amazingly SIMPLE, and kick my *** for not thinking of it myself.)
Get a bolt with a 3/8" head, attach two (2) nuts on the bolt. These nuts will act as your jam-nuts when tightening/loosening the trans plug.
When tightening the plug:
1) Insert the bolt head into the Trans plug (where the Allen key would normally go),
2) Making sure the two nuts you screwed onto the bolt are tight up against each other, use the TOP NUT to tighten, turning bolt to the right. (Righty Tighty, Lefty Loosey)
To loosen trans plug, reverse process, but...:
1) Wrench on the BOTTOM NUT to the left, being sure both "lock nuts" are snug against each other.
HOPE THIS TRICK HELPS.
NEAL
Old Jun 11, 2016 | 08:26 PM
cggorman's Avatar
cggorman
That's an OK trick if you're stuck somewhere on the road I suppose, but any place that sells bolts will also sell Allen wrenches. Just get the wrench.
Old Jun 11, 2016 | 10:37 PM
breakman's Avatar
breakman
I wouldn't even bother using a torque wrench just snug it up good.
Old Jun 11, 2016 | 11:12 PM
lh4x4's Avatar
lh4x4
Buy a bigger one. Any store that has tools will have one. Like Maynards, Home Depot, Lowes and hardware stores.
Adding tools is a cool thing to do.
Old Jun 11, 2016 | 11:18 PM
Zerk's Avatar
Zerk
Old thread. You think the guy was screwing around? If you can't handle that, you shouldn't own a bike, even if the dealer does all the work.
Old Jun 11, 2016 | 11:20 PM
ndallmer's Avatar
ndallmer
6th Gear
"That's an OK trick if you're stuck somewhere on the road I suppose, but any place that sells bolts will also sell Allen wrenches. Just get the wrench"
You'd think so...but from personal experience I've run into (at all my local stores) the problem of stores only offering popular size Allen keys. Hence this work-around.
TRUST ME, if I had the option of buying the required size Allen key at that moment, I would have purchased it. But when broken down on the side of the road, finding a fully stocked tool chest with every conceivable tool at your fingertips packed in someone's saddlebag is unlikely. But a bolt and two nuts is more likely. For instance, the bolts that attach your Choke/Enricher Bracket to the rockers can be cobbled together in a pinch. (Yeah, they'll work. Trust me.)
Safe Riding!
Old Jun 11, 2016 | 11:28 PM
cggorman's Avatar
cggorman
Fair enough. Pack that 3/8 wrench and be a HERO!
Old Jun 11, 2016 | 11:39 PM
ndallmer's Avatar
ndallmer
6th Gear
Already done, MANY moons ago. Haha.
Cheers!
Zerk's Avatar
Zerk
Both my bikes have 3/8 hexes, plus the rest, wrenches, breaker bars, sockets, extensions, 1/4 and 3/8, 1/2 drive, wiring diagrams, ect.
