Heated grips?
i wear leather winter gloves as well..
if you go with a set up like this, you can take apart the stock housing for the control and mount it differently, i drilled a hole in my fairing and ran the temp **** up..
again i know this is not a HD... but i do run heated grips and i ride all year round... and rain and shine... if your looking to ride in colder weather, you may want to think about making a set up for hand guards to make them quick release... they look ugly but man do they help!
i got a set of ATV gaurds... and the mounts where to short
welded in some extensions
then powder and now it clears my controls
this is a good option as well and they come off with just 2 bolts... can be put on in the winter and pulled off for any other time... sorry to side track a bit but there are some cool options out there other than just grips
Actually, at 65 and an arthritic foot, once the temps get so there's ice on the road I quit riding, so I'm thinking grips and insulated gloves will work fine.
I'll take a look at what was suggested, thanks again.
Al
The main thing is once you have heated grips (good adjustable ones) you'll be surprised how often you use them. For instance you may not have the heated gloves packed when riding 70 degrees in a light rain, which can start getting cold after a while. I'm not talking about your hands, but rather just getting chilled overall. When you get chilled your body starts slowing blood flow to your extremities (hands). This doesn't happen when you're holding on to something warm. Doing this (in addition to keeping your hands warm) actually helps keep the rest of your body from getting chilled.
