Heated grips?
Old Sep 27, 2012 | 10:46 PM
Bluehighways's Avatar
Bluehighways
Originally Posted by soft 02
What cons other than the HD units failing...
Cons:
Heated Grips don't heat up instantly like the new gloves do. The inside the bar Polly-Heaters that I have take a minute or two to come up to temp. The Directly heated grips that I had on a BMW (that I owned once) came up to temp in about 30 seconds. Because heated grips can take time to come up top temp, they can also wind up getting just a bit too warm . . . . if you don't pay attention to them
Installing Heated Grips takes more technical work than putting on a pair of gloves. Said technical work either has to be done by you or you have to pay someone else to do it for you.
However . . . I always used to think that Heated Grips were kind of silly. BUT, once I had a bike with Heated Grips . . . I am now a believer. For really cold stuff I also have a pair of heated gloves. But down to about 40-45*F a good set of unheated gloves and Heated Grips make it all OK.
Old Sep 28, 2012 | 06:03 AM
HDexplorer's Avatar
HDexplorer
Well, I love the look of Heat Demons control switch but not big on the price. Polly Heaters look solid, simple and have a great price but what's with the switch?
Has anyone installed the polly's and where did you put the fugly switch?
workman70
May 11, 2018 10:23 PM
pepper lynn
Mar 6, 2011 08:41 PM
jimsflh
Jan 14, 2011 12:45 PM
bigdoghd
Oct 14, 2007 06:35 PM
cosmicHD
Dec 21, 2006 09:32 PM
