Need wider front fender
Old Oct 1, 2012 | 05:52 AM
stilup's Avatar
stilup
Default Need wider front fender
I need to install a wider front fender.
I have the 110 metz on the front and the stock dyna fender does not keep the
wet roads from splashing all over my pant legs.
I think a Wide Glide fender would work but I need to know before I purchase one.
I couldn't find a write up on a switch over.
Any suggestions?
Old Oct 1, 2012 | 06:48 AM
Jeff's 1st Harley's Avatar
Jeff's 1st Harley
Any suggestions?
Stilup I just saw one on ebay it is black and looks a little scratched, but it might work for you. It looks like he put the measurements down to help determine if it will fit. Good luck.
Old Oct 1, 2012 | 08:47 AM
Baeseman1's Avatar
Baeseman1
Do you have a 21" on the front? Not sure how close the fender radius will match up with a 19" tire. Look at aftermarket fenders too. KC International is where I got my Long Boy from in my sig pic.
Old Oct 1, 2012 | 12:18 PM
nevil's Avatar
nevil
I don't think the WG fender is any wider than yours, just the mounts are wider to fit the wider front end. Now it's possible that a Fat Bob fender will work. I found one on ebay and asked the seller for the mounting width but he didn't answer the question so I didn't bid on it. Other than that you probably need to look for an aftermarket unit.
Old Oct 1, 2012 | 01:23 PM
Gringoloco13's Avatar
Gringoloco13
Just an fyi no fender will keep water from soaking your pant legs. I have a aftermarket wrapped fender on mine and my pants still get soaked when riding on wet roads.
Old Oct 1, 2012 | 01:35 PM
JRK5892's Avatar
JRK5892
i ran a fat bob lid on my stock st bob fender mounts... came out sick and i ran a 120 under that on the stock 19 rim... here is a few pics below and like to my how to form years ago
https://www.hdforums.com/forum/dyna-...al-stages.html
https://www.hdforums.com/forum/dyna-...ur-fatbob.html
Old Oct 1, 2012 | 04:44 PM
stilup's Avatar
stilup
JRK5892-Nice job.
What year Fatbob fender did you use?
Did you rivet the fender like it was stock?
Old Oct 1, 2012 | 04:49 PM
JRK5892's Avatar
JRK5892
no idea what year... they are all the same... i think it was an 07... yes i did rivit it, however if i was to do it again i would just weld it up for a cleaner finish... i rolled it back a bit on the mount to have it wrap the tire a bit more and have a bobbed look in front, then cut and lowered the mounts for the stock fender so it would hug nice and tight... all in all was pretty easy... if you do this and rivit it and would like it welded you can send it out marked and we can weld it all up and powder coat it for you... clean smooth finish and you can just bolt her on!
Old Oct 1, 2012 | 05:06 PM
stilup's Avatar
stilup
JRK5892 , that sounds good.
I'll PM you when I get there,
My tire fits my fender tight already, don't know if I need to extend the mounts yet.
Got to look for a fender.
Old Oct 1, 2012 | 06:42 PM
stilup's Avatar
stilup
http://www.ebay.com/itm/Custom-Raw-S...00319853006%26
What do think of this fender?
I have a 19"x 4 1/2" wide front tire.
