Hmmmm....think I need some help and advice here :-(
Old Oct 1, 2012 | 06:37 AM
Gaffy52's Avatar
Gaffy52
Default Hmmmm....think I need some help and advice here :-(
My '07 Bob threw a U1097 Loss of Speedometer Serial data TSM/TSSM fault code again whilst I was out and about again. No apparent downside anywhere on the bike that I could see and so I checked and cleared the code via the speedo. Rode home and it's not happened again. Went out and checked it again this morning and all is still good.
Kinda random and intermittent - so I am inclined to not worry until something is obvious that's triggering it?
Thoughts...............
As always my thanks to you guys.
Old Oct 1, 2012 | 07:27 AM
WS6 Formula's Avatar
WS6 Formula
Click on the blue arrow for more info.
Originally Posted by WS6 Formula
I've had it happen to mine but only the speedo was doing it. I also got code U1097 as well as other codes. The service manual pointed to every other component on the bike because the manual was written as if the speedometer would never fail. I ended up getting another speedometer and that took care of it. In your situation with both gauges, I would check your battery power as well as connections (battery connections), usually speedo's tach's and electronics act erratically with low voltage (battery on its way out) or voltage spikes (loose connection).
Old Oct 1, 2012 | 07:37 AM
snstiggy's Avatar
snstiggy
Check your battery terminals. I don't know what your weather is across the pond but last year we had a cold spell then a heat wave within a few days. My electrical system got weird to say the least. Another member on the forum suggested checking the battery terminals and tighten. I tightened them up and I didn't have any other problems with it since.
Good luck
Old Oct 1, 2012 | 10:36 AM
Gaffy52's Avatar
Gaffy52
Good luck
I'll certainly give it a go - thanks as always!
Crashstone
Electrical/Lighting/Alarm
Sep 26, 2018 11:49 AM
rwb1
Aug 28, 2012 06:17 PM
bobber96706
Sep 13, 2009 04:15 PM
grubby
Feb 25, 2009 11:13 PM
Locmoss
Aug 11, 2008 11:02 PM
