injectors
Old Jan 27, 2007 | 11:41 PM
Georgia Rider's Avatar
Georgia Rider
Default RE: injectors
Still running the 8 degree injectors. Had my bike bored out to 95 inches with Andrews TW37H cams, .030 gasket, and SE flat top forged pistons. Bike already had the 1550 download, SE air cleaner and slip-ons. Road 120 miles today and she performed perfect.
Old Oct 17, 2007 | 11:31 AM
costaza's Avatar
costaza
Well I saw the psec for the injectors. Flow rate for the 8s is 3.89 gr/sec, and the 25 is 4.91gr/sec. So if you keep the 8 download I would think it would be richer with the 25 injectors. I believe they work on voltage pulses, so for the same duration of pulse the 25 deg flows more according to the rate
Any techs out there to really confirms that , since my warrantyy is out, I have WG 06 with 8 deg and stage 1. If I buy the 25 and install them, I shouldl run richer with the 8 deg download
Thanks
Old Oct 17, 2007 | 01:14 PM
atillman's Avatar
atillman
I have an 06 Wide Glide - built in Aug 05 - and still have the 8 degree injectors, I also have the stage 1, SE slip-ons with the download for the stage 1/SE Slip-ons. I get an occasional stumble if the bike is not completely warmed up and it almost always happens with the bike leaning in a turn.
Old Oct 17, 2007 | 07:23 PM
dlstanf2's Avatar
dlstanf2
I've got the 8's as well. No problems here. Was going to get the 25's, but since mine runs so well with the 8's, I kept the 8's.
Old Oct 17, 2007 | 07:30 PM
Original Junior's Avatar
Original Junior
From: The birthplace of our nation- Philadelphia proud!
I have the 8's andshe finally runs after I broke down and got the SERT. I had a SE Race Fueler on there and it helped but the SERT is much better. ANyone looking for a slightly used Race Fueler for an 06 Dyna?
Old Sep 20, 2008 | 08:59 PM
WildBill76's Avatar
WildBill76
Mine were fine for 10,000 miles, but then every so often at a steady speed the engine would surge and stumble for just a few seconds. Sometimes it did not reoccur for several miles.
Old Sep 20, 2008 | 09:07 PM
WildBill76's Avatar
WildBill76
Wow! If I had that many bikes, I wouldn't know which one to ride.
Segerfan
Jul 9, 2013 07:08 PM
Nova Joe
Sep 3, 2012 09:42 PM
Big D
Jun 10, 2006 10:48 PM
Whiffleboy
Apr 19, 2006 01:14 PM
mrbuster
Feb 24, 2006 10:32 PM
