2012 SB Mini Apes on a 2012 FXDC
Old Oct 2, 2012 | 09:37 PM
Warrior 72's Avatar
Warrior 72
Default 2012 SB Mini Apes on a 2012 FXDC
I've spent the last hour searching for a answer, couldn't find it, so here's the question. When I picked up my 2012 FXDC I had the parts department get me the 2012 FXDB Mini Apes. I also got a new clutch cable, both throttle cables, a new brake line and crush washers. I looked in my service manual, and the throttle cables look pretty easy, but the clutch cable looks like a pain. It looks like there's a lot of slack in the clutch cable and brake line, and chance of getting away with not replacing everything? Thanks in advance.
Old Oct 3, 2012 | 02:26 PM
pontiac69's Avatar
pontiac69
How much taller are the new bars over the stock ones. I know stock cables will work on bars up to 12" tall. On my 11 wide glide i put 12" z bars and used stock street bob cables. That is clutch, 2 throttle, and brake cables. I did my install last year and i never did anything like it. Turned out to be a piece of cake. I am only about an hour away if you need a hand with the job.
Old Oct 3, 2012 | 02:53 PM
USMCBattles's Avatar
USMCBattles
if u wanna return the bars i can check my house for my stock sb bars
Old Oct 3, 2012 | 03:24 PM
Bagger_Vance's Avatar
Bagger_Vance
I don't know if the cables are the same as my '07 FXD but all I had to do was re-route my clutch cable. You might want to give that a shot before you start digging into it. I also bent my brake line to get it to work but had to replace the throttle and return cables with longer.
Old Oct 3, 2012 | 08:26 PM
oubronco's Avatar
oubronco
I installed the Street Bob bars on my 2011 Super Glide and didn't have to change any cables
Old Oct 3, 2012 | 08:36 PM
Warrior 72's Avatar
Warrior 72
Thanks for the offer Pontiac69, I'm going to trry the install tommorow, I'll send you a PM if I need any help. I looked at the clutch cable and it looks like it has a lot of slack, so if I don't have to open that up it should be pretty easy. Where in PA do you live?
USMCBattles, thanks for the offer, but I will be doing the install tomorrow.
Old Oct 3, 2012 | 10:34 PM
pontiac69's Avatar
pontiac69
You could run the clutch cable up the right side down tube. That's what I did and it gave me 2" extra. I'm in East Stroudsburg. I am home all day tomorrow so just send me a pm if you have a question.
AMP'd
May 28, 2018 04:28 PM
HWill
Aug 7, 2013 03:38 PM
Houston_t
May 16, 2012 09:47 PM
sickboy949
Aug 14, 2011 09:19 AM
J-RoX
Jan 21, 2010 03:35 PM
