Throttle screwed up 2008 FXDC
Old Oct 2, 2012 | 10:17 PM
ChiroRick's Avatar
ChiroRick
Default Throttle screwed up 2008 FXDC
Took my throttle off today to get my new 4in curved risers installed...when I had my new bars put on, the throttle cables were ran between the fork tubes just below the top of the triple tree, then to the throttle, because the original bars required a longer cable, and putting lower bars required routing the throttle cables that way to prevent it from sticking out. Putting on the risers put the bar closer to stock position, so I had to unhook the throttle cables, and put them the way they should be. Put the switch housing back together, and the throttle won't snap back. When I roll the throttle back, it stays there. Tried different combinations of loosening one cable, tightening another, and vice versa. The cable that is actually activating the throttle is working just fine, but it's not snapping it back. (That's the best way I can describe it). The throttle cables are in the right position. Skinny cable in the front, fat cable closest to the rider. Suggestions? Frustrating...I don't know how to make this right.
Old Oct 2, 2012 | 11:05 PM
RA51's Avatar
RA51
Have you checked the little star tensioner on the bottom of your throttle housing ? Make sure it is loose or the throttle will not snap back.
Old Oct 3, 2012 | 09:49 AM
ChiroRick's Avatar
ChiroRick
Yes sir. Even took it off altogether to see if that was the problem. It wasn't.
Old Oct 3, 2012 | 10:44 AM
RA51's Avatar
RA51
Loosen the throttle housing screws a little an see if it works. Could you have pushed the grip on the bar to far an rubbing the end of the bar ?
Old Oct 3, 2012 | 02:25 PM
ChiroRick's Avatar
ChiroRick
Problem Solved! Lubed up the cables, throttle adjustment bolts, and the friction plate. Snaps right back into place now.
dragon78
Nov 13, 2019 10:25 PM
Atlaska
Sep 17, 2014 03:07 PM
teedub79
May 22, 2013 07:48 AM
rgjujitsu
Oct 17, 2012 03:40 PM
petejoe43
Mar 27, 2011 08:17 AM
