Removing Tank Emblem
Old Oct 8, 2012 | 02:24 PM
whitewolf001's Avatar
whitewolf001
It's cause I'm from TN, don't take it personally guys, we just know how to get it done here... GIT ER DONE!!!
Old Oct 8, 2012 | 02:36 PM
Mid-Night-Rider's Avatar
Mid-Night-Rider
You'll need: a toilet paper roll, a paper clip, and a stick of dynamite.
Seriously though, I removed mine a few months ago. Simple stuff. You'll find several threads on this site about this, and they all say the same general things:
Heat gun, WD40, floss/fishing line, gasoline. And it worked great. Should only take 2 beers to complete.
Old Oct 8, 2012 | 02:46 PM
rs87277's Avatar
rs87277
Dealer took mine off with black denem paint, there is still an outline, nothing I can do, u can't buff out flat paint
Old Oct 8, 2012 | 03:15 PM
whitewolf001
Why not put one of the old school badges on in its place to hide the outline?
Old Oct 8, 2012 | 07:33 PM
Cruzados's Avatar
Cruzados
4th Gear
.....or...maybe heating up the emblem with a blow torch.....
Old Oct 8, 2012 | 07:37 PM
mmcbeat's Avatar
mmcbeat
I think if you park it in the sun for a few hours, the outline will fade away.
Old Oct 8, 2012 | 09:45 PM
rs87277's Avatar
rs87277
I tried the sun option, nothing happened
Old Oct 8, 2012 | 10:01 PM
FXD_TG's Avatar
FXD_TG
The only caution I would offer when removing tank emblems (or any other emblems that are attached with adhesive foam tape) is to be patient and resist the temptation to pull the emblem off using any leverage once you have a corner or edge loose.
Work the fishing line all the way the way under the emblem so that it just about falls away from the painted surface.
If you try to pull it off by lifting just one edge, the opposite edge(s) will be pressed into and mar the clear coat by leaving edge marks that may or may not buff-out.
converted
Mar 14, 2013 02:40 AM
89Speedy
Aug 24, 2012 05:58 AM
aamodt22
May 29, 2011 02:07 PM
yank
Jul 21, 2009 02:21 AM
TwoBaggerz
Jan 10, 2007 11:50 AM
