16" front wheel on a Streetbob
Old Oct 10, 2012 | 04:30 PM
AVy8lo's Avatar
AVy8lo
Default 16" front wheel on a Streetbob
Has anyone tried to use a 48 sportster 16" front wheel on a Streetbob? I would like to switch wheels to get that fat look in front but I don't want to modify my 19" stock wheel hub to do it.
Old Oct 10, 2012 | 04:33 PM
Limey's Avatar
Limey
There's quite a few on here have put a 16" front wheel on, do a bit of digging round
I'm going to get a 17" rim on the front same as the rear and laced to the original front hub.
Old Oct 10, 2012 | 05:14 PM
Reindeer's Avatar
Reindeer
I don't think a 48 wheel will be a direct bolt-on. Narrow glide vs. Mid-Glide forks. I'm sure that you can make it work with some combination of spacers, but you need to verify that the axles are the same diameter.
Old Oct 10, 2012 | 05:31 PM
SuperFastGlide's Avatar
SuperFastGlide
crossbones wheel on mine
Old Oct 10, 2012 | 05:42 PM
Mike650's Avatar
Mike650
i asked my dealer a similar question the other day. i wanted to know if a 13 spoke sportster front wheel off a 2012 sporty would fit my 2012 dyna. they gave me a simple answer. no.
Old Oct 10, 2012 | 06:21 PM
wag_oh_neer's Avatar
wag_oh_neer
I just laced a 16" wheel hoop to my stock hub. If you go this route there are no other modifications needed, unless you want to run a fender. I started a couple threads on the process, you'll have to do a search for them, I'm on my phone otherwhise I could be a little more helpful.
Old Oct 10, 2012 | 07:50 PM
whitewolf001's Avatar
whitewolf001
Is that a direct bolt or did it require some fabbing?
crusader1xxx
Jan 6, 2018 08:23 AM
hpotter
Mar 7, 2016 02:44 PM
Lockshow
Jun 16, 2013 06:56 PM
kidney_bean
Wheels/Tires
Aug 2, 2012 09:24 PM
fxrfrank
Wheels/Tires
Feb 29, 2012 10:41 AM
