Mine should be here early next week.
Already registered
All stock and the bags weren't even used.... Stored in a box!
I'm stoked for it to get here.
How much did you get yours for? ( if you don't mind me asking)
Also are you replacing your upper brake lines too? I'm not sure how far they will stretch. I think you can only go + 4" with the stock ones and that's pushing it.
How did you register it from out of state without having the VIN verified?
Already registered
I know for a fact you can get about 12-13 inches of rise out of the stock lines. I have 8" risers and sporty bars with about 4 inches of rise. Any higher and I would have had to of bent the line at the spliter. The guages were maxed out at that height. You have to remove the rubber grommet from the neck of the frame and cut the zip tie that holds the wire harness to it.
