Slight push/pull at constant speed
Old Oct 24, 2012 | 04:58 PM
Fusion777's Avatar
Fusion777
Default Slight push/pull at constant speed
Hey guys, new to the forums. I've soaked up a lot of good information lurking around, reading. Now it is my time to ask a question...........
I picked up an '07 FXDB. Loving the hell out of it.
I'm noticing an ever so slight push/pull feel as I maintain a constant speed below 35 mph. Above that speed, it's not perceptible. During acceleration also not perceptible. Almost feels like a light firing issue except engine sounds and feels strong. I was thinking primary drive belt perhaps? What do you guys think?
Old Oct 24, 2012 | 05:10 PM
Robtarra39's Avatar
Robtarra39
Almost sounds like surging, do you have open pipes and performance air cleaner, if so then it might be running a little lean and needs the stage 1 downloal, could also be a vacuum leak at the pipes or intake
Old Oct 24, 2012 | 09:05 PM
nevil's Avatar
nevil
Welcome to the forum.
It's surging. That's because it's running lean. Came from the factory that way. If the bike is stock, you might get some relief from one of the XEID's. If it's not stock, the tuner needs to be tweaked. Whaddya got in the way of mods?
Old Oct 24, 2012 | 09:08 PM
rooti's Avatar
rooti
+1 on surging unless you are lugging it. Harleys like the higher RPM's
Old Oct 24, 2012 | 10:47 PM
Gommee's Avatar
Gommee
Devil's Advocate
Mine use to do that as well. Stage 1 helped, but was still there at idling speed. With the adding of the cams and updated map, it is much better now.
Old Oct 25, 2012 | 11:42 PM
Fusion777's Avatar
Fusion777
Hey guys thanks for the responses. It's got a stock air cleaner with Vance and Hines slip ons. Just picked it up used, so dont know what its tuning histody is. Behavior is present at high rpms as well. Runs mightily once you get to freeway speeds.
Full stage 1 and retune seems to be a no brainer from the sound of it. That stock aircleaner is ugly anyway!
Old Oct 25, 2012 | 11:58 PM
Gommee's Avatar
Gommee
Devil's Advocate
Try running some Seafoam through it to clean the fuel system out.
Old Oct 29, 2012 | 03:24 AM
Fusion777's Avatar
Fusion777
Offtopic, Nevil I love the front fender of yours. Where'd you find that?
Old Oct 29, 2012 | 09:03 AM
nevil's Avatar
nevil
Thanks, it's a Custom Chrome fender called the Forty. Had it pc'd by Joe from Powder Pros.
mavantix
2014-2024 Touring Models
Apr 13, 2015 11:50 AM
BurpleHugger
Aug 15, 2011 02:16 PM
DrewCfromSC
EVO
23
Jun 10, 2011 05:45 AM
davenportm
Oct 15, 2007 10:34 AM
Magic Mule
Jul 9, 2006 01:28 PM
