Clutch Adjustment Question
Old Nov 11, 2012 | 08:00 PM
WideGlideFever's Avatar
WideGlideFever
Default Clutch Adjustment Question
What kind of tool are you guys using when tightening down the jam nut for the clutch adjuster screw in the primary? Manual says to hold the clutch adjuster screw with an allen wrench while tightening down the jam nut. Obviously you cant use a socket for the jam nut while using an allen wrench at the same time, but the standard wrenches I have dont seem to allow me to get on the jam not properly to tighten it down. Do you have to have one of those fancy wrenches that pivot?
Old Nov 11, 2012 | 08:12 PM
p51bombay's Avatar
p51bombay
Standard combination wrench works, its not ideal but either the open or box end works well enough - ideally a deep offset box end would be best.
Old Nov 11, 2012 | 08:18 PM
WideGlideFever
Yep, dont have any of those, another reason to go out and buy more tools
Sand850
General Topics/Tech Tips
Nov 3, 2016 07:27 AM
wjohn453700
Nov 19, 2013 12:11 PM
Jaymac3772
Apr 12, 2011 08:00 PM
R_W_B
Dec 9, 2010 04:12 PM
Toe Knee
Apr 11, 2010 07:33 AM
