Floor boards
Old Nov 16, 2012 | 12:59 PM
TFreese's Avatar
TFreese
2nd Gear
Originally Posted by 08fxdf43202
The answer is YES... if you have mid control foot pegs.
Have you considered 2012 Switch Back floor boards? I installed them on my 08 FXDF and am very happy with them.
HD has them as a kit in their accessory catalog.
Yes I have the mid controls. Do you have to just pull the primary cover or the inner primary cover also and why?
Old Nov 16, 2012 | 02:24 PM
Jacoblb's Avatar
Jacoblb
The install is almost identical to doing forwards except you have foot boards to bolt up as well. The mids go through your primary.
Old Nov 16, 2012 | 04:08 PM
TFreese's Avatar
TFreese
2nd Gear
It would be nice to install without removing the covers. Is that possible?
Old Nov 16, 2012 | 04:28 PM
perki48's Avatar
perki48
https://www.hdforums.com/forum/dyna-...0500247-4.html
See post 32 & 33
Old Nov 16, 2012 | 07:10 PM
08fxdf43202's Avatar
08fxdf43202
Originally Posted by perki48
Nice post...
Old Nov 17, 2012 | 05:34 AM
blueangel73's Avatar
blueangel73
This is the fastest way to go about adding the footboards without having to pull the primary. Just find a way to keep the unused stock shift linkage from moving around. When you have the $$$ or need the work, have the inner and outer primary removed and have the linkage removed also. Call me a cheap ***, but when I went to forwards I simply used a ziptie and let the linkage hang from the new shift rod loosely to avoid binding, the rod could move freely when shifting and the stock linkage didn't move. after about 6 months I had the cash to get the linkage removed and the holes plugged.
Old Nov 17, 2012 | 10:41 AM
dan z's Avatar
dan z
Ive got a 2003 FXD the parts book says 2006 and later.
Anyone know why I put them on my 2003???
Thanks
Dano
Old Nov 17, 2012 | 11:43 AM
blueangel73
Thanks
Dano
I would say its because you don't know how to read, but you were able to get to this thread, so maybe it's just dumb luck.
Old Nov 18, 2012 | 03:38 PM
Qdog002's Avatar
Qdog002
HD has the kit for $399.99. Has all the parts and uses your stock shift lever
Old Nov 18, 2012 | 04:25 PM
perki48's Avatar
perki48
Check your on-line dealers, they can save you a bunch.
