nut size.
Old Nov 18, 2012 | 05:12 AM
oakspeed's Avatar
oakspeed
Default nut size.
can anyone tell me what size socket i need to remove the nut from the top of the fork tube on a 2010 fxdwg?
i need to drop my progressive springs in, and i havent got a socket big enough. i need to go out and buy one, but i dont know the size. thanks.
Old Nov 18, 2012 | 07:36 AM
Notgrownup's Avatar
Notgrownup
I believe it's 36MM
Old Nov 18, 2012 | 08:40 AM
oakspeed's Avatar
oakspeed
thanks.
Old Nov 19, 2012 | 10:35 AM
SC-Longhair's Avatar
SC-Longhair
35mm or 1 3/8".
I usually wrap the flats with some blue painters tape once around. 1) to protect the chrome 2) makes a nice snug fit so I can control it a little better when the threads let loose.
I found the socket at auto-zone if I remember.
Old Nov 19, 2012 | 11:13 AM
rs87277's Avatar
rs87277
ya wrap it with painters tape, also the metric fits better than the standard socket
Old Nov 19, 2012 | 11:15 AM
Hogpro's Avatar
Hogpro
Former Sponsor
1 3/8" is the correct size for the fork tube caps.
Old Nov 19, 2012 | 12:09 PM
lo-rider's Avatar
lo-rider
You need to pickup a cheap dial caliper.
Old Nov 19, 2012 | 12:16 PM
rs87277's Avatar
rs87277
I have the standard and the metric socket.
The metric is a much better fit
Old Nov 19, 2012 | 12:18 PM
Notgrownup's Avatar
Notgrownup
Well hell... learn sumtin all the time..i've been using a 36mm...it did have a little wiggle...LOL...
Old Nov 19, 2012 | 07:21 PM
p51bombay's Avatar
p51bombay
That;s because its 35mm, not 1-3/8".......its close but not quite. I think Jim's is the only one making a 35mm socket for it unless you use a standard 35mm 6point socket, the only real reason for those lo profile ones is to clear the handlebars so if you don't mind moving them it will save quite a bit.
