Fuel Pump fuse for '12 FatBob
Old Dec 15, 2012 | 04:05 PM
capnkaos's Avatar
capnkaos
6th Gear
Default Fuel Pump fuse for '12 FatBob
Hello all. Have ordered a service manual but hasn't arrived yet. Owner's manual states there are only 3 fuses, all located under the left cover panel and all are general system fuses. I need to remove the tank to move front turn signals to the forks. Can anyone tell me whether a fp fuse exists for this model and where it might be? Thanks in advance.
Old Dec 15, 2012 | 04:18 PM
Slvr764's Avatar
Slvr764
Check in the ecu cover. Thats where they are on my 07. There should be one extra atleast.
Old Dec 15, 2012 | 04:33 PM
p51bombay's Avatar
p51bombay
This is a 2010 but its likely the same position, to check remove it and see if the fuel pump runs when you switch on the ignition.
Old Dec 15, 2012 | 04:44 PM
capnkaos's Avatar
capnkaos
6th Gear
Thanks for the replies. p51, your image won't display for me. Slvr, tbh, I don't know where the ecu is on this bike.
Old Dec 15, 2012 | 04:52 PM
p51bombay's Avatar
p51bombay
Right click - view image
Left hand side cover under the seat, under there on the far left is a row of three fuses - should be the middle one.
Old Dec 15, 2012 | 05:11 PM
capnkaos's Avatar
capnkaos
6th Gear
Thanks p51. They must have changed things. As stated in the manual, I have 3 fuses in the fuse block: Main, P&A and Battery. The 40A main disconnects everything, 15A P&A is for accessories and the 15A Battery protects all the circuits. Did pull the two 15As but the still charged when switching on the ignition. I guess I'll have to wait for the service manual on how to discharge the fuel system.
Old Dec 15, 2012 | 06:23 PM
Slvr764's Avatar
Slvr764
That wont tell you jack since you opened the circuit by pulling it out. Just hold it up to light, its transparent so you will see the break if it's a bad fuse.
Old Dec 15, 2012 | 06:40 PM
p51bombay's Avatar
p51bombay
He wasn't looking for a problem, he wanted to remove the fuse and run the engine to depressurize the system before removing the tank.
Old Dec 15, 2012 | 06:41 PM
arkstreetbob's Avatar
arkstreetbob
Remove the battery cable.
Old Dec 15, 2012 | 06:45 PM
p51bombay's Avatar
p51bombay
It would be tough to run the engine if you do that me thinks.
